HP 9200c Scanner Jam
  • Geo
    • 662
    [Jamming] HP 9200c Scanner Jam
    Hi all.
    Have a HP 9200C scanner that will constantly jam when feeding paper.Feeder will pull the paper in and stop with the leading edge 1-2 in ion the glass.Cleaned all the sensors and rollers. My feeling is one of the sensors is goofy.Any advice would be much appreciated
    I know copiers and printers. This is my first HP9200 scanner..
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • gerryhuerta
      AccService
      • Jul 2009
      • 198
      check this out: ADF jam
      ADF jams can occur in three places inside the ADF.
      Registration-sensor jam
      If the registration sensor does not detect the trailing edge of the media after the leading edge
      reaches the scan-ready position, the scanner-controller board determines that an ADF jam has
      occurred.
      Also, when the scanner duplexer is in use, if the registration sensor does not detect the leading edge
      of the media after a specific period of time after media enters the duplexer, the scanner-controller
      board determines that an ADF jam has occurred.
      Read-sensor jam
      If the read sensor does not detect the leading edge of the media within a specific period of time, or if
      the read sensor does not detect the trailing edge of the media within a specific period of time after it
      detects the leading edge, the scanner-controller board determines that an ADF jam has occurred.
      Exit-sensor jam
      If the exit sensor does not detect the leading edge of the media within a specific period of time after
      the leading edge reaches the read sensor, or if the exit sensor does not detect the trailing edge of
      the media within a specific period of time after the read sensor detects the trailing edge, the scannercontroller
      • gerryhuerta
        AccService
        • Jul 2009
        • 198
        if that dosent halp you out try this:
        Scanner tests
        The following diagnostic tests are available for the scanner. They can be found in the
        DIAGNOSTICS
        menu on the control panel.
        Lower lamp-This test turns on the lamp and a “Lower Lamp (scanner) is on” message appears
        on the control panel. The user must verify that the lamp is on.
        Sensors-This tests the ADF Empty, Register, ADF Jam Cover, ADF Output Bin Full, and Flatbed
        Cover Open sensors. The user must manually activate the sensors to verify them.
        ADF input motor-This test turns on the ADF input motor and a “ADF Input Motor is on” message
        appears on the control panel. The user must verify that the motor is on.
        ADF input reverse-This test turns on the ADF input motor and a “ADF Input Motor is on”
        message appears on the control panel. The user must verify that the motor is on.
        Flatbed motor-This test turns on the flatbed motor and a “ADF Output Motor is on” message
        ADF read motor-This test turns on the ADF read motor and a “ADF Read Motor is on” message
        ADF read motor reverse-This test turns on the ADF read motor and a “ADF Read Motor is on”
        ADF duplex solenoid
        ADF LED indicator
        manualy check the sensors if they are working, you can stick a flat head screw driver in the middle of the sensor, check the screen to see if the message changes with ever sensor.
        • Geo
          • 662
          Gerryhuerta
          Thanks for your help. Do you know the part # for the 3 sensors?
          Have a good NEW YEAR!
          • faxman28
            • 436
            Is the paper coming out on to the flatbed glass? If it is the clear mylar sheet is installed incorrectly or missing, this is hp version of slit glass or scan glass.
            • Geo
              • 662
              The lead edge of the org will feed about 2 inches onto the scanner glass. It stops every time in the same place.It does not matter if your feeding single or multiple sheets.
              • faxman28
                • 436
                mylar sheet replacement.pdf
                see the attached doc, When you lift up the doc feeder the paper is hanging out the bottom ? The mylar sheet when it is installed correctly (if it is even there) makes the org go around the white guide to exit to the " exit area of the doc feeder" , Usually what happens is the customer either removes a jam from that area or replaces the mylar sheet and they don't tuck the mylar sheet back into the guide correctly and the org comes out on the glass. Common call for the digital senders and some of HP's mfps like the 4345mfp. Most of the issues with the digital senders I have come across are feed rollers , sep pad
                (these wear out fast) and scan to folder or email.
                • RMParker
                  I agree with faxman28. This is normally a mylar issue.
                  • Geo
                    • 662
                    faxman28
                    You were right on the money.the mylar sheet was missing. This was the first H.P. scanner I played with and I am surprised how flimsy and easy the mylar is to remove! I would have thought it would be beefier (good if per call bad if contract)
                    Thanks again for the help!
