HP CLJ 2600 ghost image, tried diff toners, new fuser and paper settings??
  • Bri Ski
    • 48
    Usually one of those things resolves this problem. seems to only be doing it with black,
    tried three diff black toners and a new fuser. still does it. tried paper settings fromm thick to thin, no effect. Any one have a suggestion? beginning to think its a bad batch of toner
    colors do not ghost but black does. Thanks for any help, Machine has less than 30k prints
    transfer belt is in great shape and clean.
  • JustManuals
    • Jan 2006
    • 9838
    Just Manuals | The Internet's largest selection of manuals | Instant Downloads
    Paul@justmanuals.com
      • 23009
      OEM toner or compatible? =^..^=
      • Bri Ski
        • 48
        It is OEM toner
        • CanonHPTech
          • Apr 2007
          • 235
          Can you show us a sample? Just curious how much of a ghost you are getting. I mean is it just a slight halo/double effect or are you seeing the image repeating later down the page.
          The glass maybe half full, but less is more...
          Printer + Fax + Copier = Jack Of Many Trades,
          but Master Of None
          Color Copier = Not A Color Printer
          InkJet MFP = Not A Fax Machine
          B/W Copier = Not A Press
          Finisher = Deal Closer (salesman, not accessory)
          Copier Tech = Admin's Stress Ball (Scapegoat)
          • prntrfxr
            • 1622
            weakness with the power supplies in these machines, but update firmware first since that's a freebie
            Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
            • cetverooki
              • 53
              can you check distance between ghosted images. or between original and ghost? this can give you exact source of problem or at least narrow down search for it.
