HP P3005x Drive noise and formatter board questions
  • vedder
    • 131
    Hi everyone, I`m wondering if anyone can help me with some questions I have.
    I have 2 HP P3005x printers, one has a error code 49? which on ivestigation leads me to the formatter board, I have swapped it with another one and it works fine, this machine is not under any sort of contract with us so the price isn`t a issue, i.e, I don`t need to try and do it on the cheap, baking etc. My question is, if I do replace the board, do I need to do anything else, firmware etc?
    Second question, I have another printer same model, with a loud noise coming from the drive/exit sensor, I understand that the gears can get worn/skip when driving the fuser, my question is, can anyone tell me the part numbers for these gears? I have changed some a long time ago but on a different model, a 24 something? and was wondering if there are the same part.
    I am a trained engineer, but only stumble across HP everynow and then, any help/tips would be greatfully appreciated.
    Cheers
    • 23002
    Originally posted by vedder
    ... one has a error code 49? which on investigation leads me to the formatter board, I have swapped it with another one and it works fine, this machine is not under any sort of contract with us so the price isn`t a issue, i.e, I don`t need to try and do it on the cheap, baking etc. My question is, if I do replace the board, do I need to do anything else, firmware etc? ...
    No, you can just install the PWB and be done with it.
    There's another thing to keep in mind though. A lot of 49.xxxx codes are caused by corrupt print data, that's all. So, that leads us into a couple of questions:
    Under what circumstances do you get the codes? Often it's a specific document, a specific application, or a specific driver. The first thing that I'd do is delete the existing print driver and re-install it from a fresh download. If you can narrow it down even further to a specific document that's even better.
    I remember a specific case where the codes only occurred when printing from a web based document storage application. The documents printed fine before being stored, but not so after being stored. Just a thought ...
    You'll need one each of these part numbers: RC1-3609-020, RC1-3610-000, RU5-0956-000, RU5-0957-000, RU5-0958-000, RU5-0959-000. They are sold as a kit from http://tsaworld.com/ under part number: KP3005X
    I use many of these kits. They include the four drive gears on the frame, the pressure roller gear, and the pressure roller bushings, all of which will need changing.
    And no, they're not the same as the 24xx series. =^..^=
    • vedder
      • 131
      Hi, thanks very much for your quick and helpful reply.
      What you was saying about the board is interesting, although I`m not sure if it applies to this problem, I have taken the board off another machine (the one with the noisy gears) and it works fine, printing from all programs etc, it does lock up at different times etc, on start up, 10 minutes later, etc, plus it locked up with no jobs going to it with the network cable unplugged, I think I will order up the board and see how it goes.
      Thanks again for the assistance.
        • 23002
        ... plus it locked up with no jobs going to it with the network cable unplugged, ...
        That rules out corrupt print data. The formatter is what you need. =^..^=
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
          Paul@justmanuals.com
          • austonrush
            Sharp & HP Tech
            • 234
            When you install the drive gear kit (4 gears listed above) do not lubricate the gears. They are not compatible with the 2400 series. Most lubricants will actually cause the grinding to come back quicker than if you just leave them grease free.
            FYI the formatters for the P3005/ M3027/ M3035 are all very unreliable and you definitely need a new one.
            • mjunkaged
              • 383
              Re: HP P3005x Drive noise questions
              FYI: If, after you replace all the gears in this POS!!!
              And STILL have a 'RUM RUM RUM RUM RUM ' noise, it's NOT the gears or fuser. What it is, is that the lower left metal tab that the lower left hole of the fuser screws to is flexing. This is if the noise happens immediately on high speed in the forward direction.
              I fixed mine by JAMMING a Q-tip shaft into the loose (about 1/16") space between that tab and the side frame. In order to get it to fit, I had to pry the tab inward long enough to slip the q-tip stem(shaft) into the gap. VOILA!! Now it does not sound like a POS, even though it STILL IS!!!
              SHAME on HP for inflicting this misery upon the world.
              • austonrush
                Sharp & HP Tech
                • 234
                Re: HP P3005x Drive noise and formatter board questions
                Never seen a frame vibration in that particular model before. Usually vibrations are caused by fan coming loose. Lol nothing like the q-tip fix! How much are you charging him for the q-tip ! Glad your found it finally!
                • austonrush
                  Sharp & HP Tech
                  • 234
                  Which gears did you replace and did you replace them at the same time as you replaced the fuser? For all those reading this post you normally need the following 4 gears plus the fuser when fixing the rumble! They NEED to be changed everytime you replace the fuser to minimize the rumbling noise.
                  • mjunkaged
                    • 383
                    What part of 'when all else fails' didn't you see? Yes, replaced ALL those, PLUS more stuff.
                    • austonrush
                      Sharp & HP Tech
                      • 234
                      lol, apparently I missed it entirely!
                      • iscott
                        • Mar 2010
                        • 344
                        • iscott
                          • Mar 2010
                          • 344
                          Sorry wrong "There" their...
                          • mjunkaged
                            • 383
                            Originally posted by iscott
                            What's up YOUR arse???? Brandon took my smart-ass reply in the humorous vein in which it was intended, and YOU seem to be highly offended. Had a bad day?? Apparently you need to chastise someone (me) in the worst way possible. Feel better now that you've attacked me from miles away at your safe, warm computer terminal? Good. Love the way you turn it into a political thing as well. Go find a political forum , or cl rants & raves, where you'll be welcomed with open arms! This is a TECH. FORUM.
                            BTW, it's mjunkaged, as in m.j. (my initials) followed by unkaged (my band).
                            • iscott
                              • Mar 2010
                              • 344
                              You forgot I also made an inference to you being lazy....and was I wrong about your political beliefs? If so I apologize.
