HP8150 jams when duplexing only
  • mushy
    • Jul 2011
    • 12
    [Jamming] HP8150 jams when duplexing only
    I have an 8150 that jams every time i duplex, some jams are almost all the way out of fuser and turned down into the inversion section, others are down through the throat of the duplex tray, it jams everytime i duplex never when not, i've tried a different duplex tray, also i have cleaned the fuser exit rollers and increased the pressure on the exit idle rollers
  • mo0651
    • 1054
    Re: HP8150 jams when duplexing only
    Had the fuser cause this itself.
    • Wild Bill
      • Jul 2005
      • 774
      I Agree try a fuser. I would use paper path test then you will know exactly where its jamming.
      Izzy
      • prntrfxr
        • 1627
        Do you hear the duplex unit kicking in? How do the rollers look in the fuser and duplex unit?
        Can be:
        Fuser
        Duplex unit
        Diverter unit
        Delivery asm
        PIU
        The reason it's jamming is timing delay. Paper movement is not moving fast enough.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • mo0651
          • 1054
          Had a field supervisor drag me along to 1 of these. He had spent 3 hours swapping everything between a good printer and the jamming printer. He just never swapped the fuser or serial number plate. Serial number plates don't cause jamming! LOL
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from
            Paul@justmanuals.com
            • otuvak
              • Aug 2010
              • 102
              Had same issue after installing new maint kit(remaned). Put old one back in and no problems. Good luck. Maybe manuals now can add something to this!
              • mushy
                • Jul 2011
                • 12
                Thanks for the ideas, i"ll be out there today with a fuser. I'll let you know what I find.
                • mushy
                  • Jul 2011
                  • 12
                  I installed a fuser from another machine and it works great, I appreciate the help
