HP LJ4100
  • copiman
    • Sep 2011
    • 861
    [Error Code] HP LJ4100
    Does anyone know if there is a reset for Error code 50.2? I have searched the manual and cannot find it. I saw Cold Reset, but I do not have the ability to print out settings. Anyway, if you do know and know where in the book, page #, I would be greatful.
  • mo0651
    • 1054
    Re: HP LJ4100
    Fuser error. Turn off for at least 15 minutes. If problem comes back it is probably a bad fuser.
    • JustManuals
      • Jan 2006
      • 9838
      Re: HP LJ4100
      Printers do not have reset codes, you're thinking of copiers. With a printer you have to actually fix something on the spot.
      Paul@justmanuals.com
        • 23009
        Re: HP LJ4100
        That's correct.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4723
          Re: HP LJ4100
          the older HP's could be turned off for 10 mins then back on and would reset "sometimes". usually that code will come back so it is best to replace the fuser
