cp3525 with 59.f0 error
  • JLSam
    • Jun 2015
    • 605
    Re: cp3525 with 59.f0 error
    Originally posted by bernielhat
    Actually I work on Most brands of printers copiers and Fax Machines and find in most that the Adhesive spongy material use to Dampen the noise of the clicks and assist in breaking the Magnetic field so hook can return. I have seen these fail in most applications and end up Removing the Damper pad completely (causes Clicking noise) or Finding a material to help in repeling the hook and dampening the noise slightly . Some times just a Piece of paper folded up and taped in place so as not to cause any sticking.
    These pads are known to cause frequent Jams as well in the Duplex units , MP trays and Regular trays. You might get a pass of an additional sheet , Typically blank because there was no job when the page was fed because the Hook did not grab the Cam Stop..
    All the manufactures have these solinoid issues. Some have found a longer lasting material.
    Paper is not enough to stop clicking. We replace the sponge with a nice velvet material. Works beautifully. Lasts forever.
    • theengel
      • Nov 2011
      • 1784
      IMO, by the time a machine is old enough for those sponges to be a problem, it's old enough to make a little noise. I don't use any padding. I've never heard a complaint about solenoid noise.
      • theengel
        • Nov 2011
        • 1784
        If you bend the curved metal piece up just a little (enough to put another mm of space between the magnet and the plate) the plate will never get magnetized. Plus, you won't ever have loose pieces of tape or anything else floating through the machine. Oh well, each tech does it different. One of the techs here (it's in another thread) uses a piece of inner-tube. I can't remember who. I prefer to use nothing. I haven't been called back on a single one since I started doing it this way (7 years ago).
        • theengel
          • Nov 2011
          • 1784
          #19
          I think we've established that the designers are nit-wits. In fact, that's what this discussion is about.
          I didn't say I've been a tech for 7 years--just that I've been bending the metal for 7 years.
          I'm allowing that each tech has their own ways. What I wouldn't allow, is that your way is better. Some techs go by the book, some get it done. And some become managers.
          • theengel
            • Nov 2011
            • 1784
            #20
            Because those certs mean everything.
            • Lance15
              • Jun 2015
              • 1086
              #21
              Just got one of these in. Told them that error was the "dispose of me" error.
              Seriously, I explained what would be involved in resolving this code. Waiting to hear back.
              I've done my time on this before. If they don't REALLY love the printer, it's time to replace it.
              • theengel
                • Nov 2011
                • 1784
                #22
                It's not that bad of a job if you can take it to the shop. But IMO it's pretty nasty in the field. I've done it twice in the field.
                • GARZA
                  #23
                  Look, forget about removing sponge pad and not replacing it, REPLACE THE PAD... You have the printer area disassembled so why not complete the job properly. One can purchase the material that will work for this solenoid at Staples, Home Depot etc. just look for shipping and mailing items/materials.
                  • theengel
                    • Nov 2011
                    • 1784
                    #24
                    Because if you replace it with another 'proper' pad, the problem will just come back in a couple of years.
                    • Lance15
                      • Jun 2015
                      • 1086
                      #25
                      In all fairness, GARZA didn't elaborate on what he/she uses. Only to not be lazy and replace the pad.
                      I use these
                      Cut 'um to fit. Remove one side that sticks to the solenoid and leave the other side on.
                      • komarville237
                        #26
                        Is there a picture of the fuser drive assembly that shows how it should be properly alligned before installing it back to the printer, because after doing all the suggested things in this post (take pad off, and all the tests) my grinding and clicking noise remains. The pic in the service manual is quite blurry, and i would like to try to allign that damn thing once more correctly before ordering a new one
                        • theengel
                          • Nov 2011
                          • 1784
                          #27
                          I don't believe the fuser drive assembly needs to be aligned. There is one gear in there that is notched, and you have to make sure that is right, but otherwise, you just put it in. Here's a link to the gear I'm talking : HP CP3525 - 59.F0 . But this would be real obvious. If you're getting clicking and grinding, you probably put something else in wrong.
                          The developer drive has to be aligned. There are some gears that have to be turned, but the manual shows how and it's not uncomplicated.
                          • komarville237
                            #28
                            Yes i alligned the cams and installed back the motor without any problems (the only hickup was that i could not turn the shaft so i turned the cams by hand). Visually there isn't anyhting wrong with the fuser drive assembly (notch in the right place), so i can't determine if it is still problematic, (the foam seemed to be sticky and i removed that), the only indication is when i try the ITB contact alienation motor component test, the test doesn't take more than half a second basically it starts and stops without anything moving in the printer. When the printer starts and i get the error just when calibrating begins, i tried to listen from where the sound comes from and i think is in the fuser drive assembly area, but still can't be sure if that's the faulty part. Thanks for your post.
                            • theengel
                              • Nov 2011
                              • 1784
                              #29
                              You're still getting the 59.f0 error?
                              You can't just remove that sponge. You have to either put another piece of padding in there (black tape, bicycle inner tube, whatever) or bend the metal piece out so that the metal plate doesn't come in such close contact with the magnet.
                              Either way, it's not like that solenoid is easy to get to. I imagine you had to kind of dismantle the gear assembly a little in order to get to it. I would question whether it was put together correctly. I know I looked at that mess and quickly decided to order a refurb one instead of messing with those gears.
                              • komarville237
                                #30
                                I didn't add another sponge or tape, or bent it and the magnet comes in contact with the metal now, so maybe i corrected the problem by removing the sticky foam but i created another one by not adding something else in its' place. Thanks a lot for your input, i'll give another go and see what happens
