Lexmark MX710CE printing magenta across entire page?
  • best-tech
    Master Technical Support
    • Nov 2014
    • 46
    [CQ] Lexmark MX710CE printing magenta across entire page?
    I have a Lexmark MX710CE printing magenta across entire page. Black prints are fine. But when printing color the whole page edge-to-edge is solid magenta. Replaced the imaging unit per Lexmark service but no change. Don't know where to look next?
    Re: Lexmark MX710CE printing magenta across entire page?
    is there a separate development unit in this machine? sounds like a failed developer or even a bad ITB belt
    • best-tech
      • Nov 2014
      • 46
      Separate drums and charge unit for each color. Already replaced them. B&W mode is fine. Color mode, doesn't matter if there's color on the print or not. Comes out solid magenta. See samples attached.Black mode.jpgColor mode.jpg
        Separate drums and charge unit for each color. Already replaced them. B&W mode is fine. Color mode, doesn't matter if there's color on the print or not. Comes out solid magenta. See samples attached.[ATTACH=CONFIG]37170[/ATTACH][ATTACH=CONFIG]37171[/ATTACH]
        that's because in color mode ( even if no color on page) the color components are put into play... you might have a grounding issue... but it looks like a DEVELOPER unit issue.. not charge
          • 22997
          Yes, you're experiencing charge loss at one of the color units or HVT. I would try swapping around the photoconductors to see if you can get the background color to change. If it doesn't change that points toward the HVT (probably on the power supply). =^..^=
          • best-tech
            • Nov 2014
            • 46
            Hey guys, narrowed it down to the magenta laser. It's staying on all the time. Most likely a board problem.
