lex x7170
  • Gab
    • Aug 2015
    • 668
    lex x7170
    I am trying to in stall this printer under win 7 but i have problems with printing. Scannisng works fine.
    I removed the old (and not working) version of this printer detached usb cable and tuirned orinter of and removed printer.
    I downloaded drivers kai stared setup . Follow the procedure and message "not correctly installed" appeared. In prnters folder printer icon appears but in programms (for example word) doesn't appear in printers list. Any idea how to install it?
  • Lance15
    • Jun 2015
    • 1086
    Re: lex x7170
    The X7170 is not officially supported in Windows 7. You can use the Vista driver.
    Unplug the USB cable and uninstall the driver/software. REBOOT
    Using the Vista driver/software, start with installing the driver/software and when it asks to plug the printer in, plug it in.
    The driver/software/Windows should take it from there.
    Please note these are basic instructions for installing any USB printer. I don't know exactly what the installation screens look like.
    • Gab
      • Aug 2015
      • 668
      Re: lex x7170
      I have done all this but allways the same, message is not installed correctly". Also i used vista drivers
      • Lance15
        • Jun 2015
        • 1086
        Re: lex x7170
        Which version of Windows 7 are you using? Home or Pro?
        The driver package is no longer showing in Add/Remove Programs?
        • dalewb74
          • Feb 2018
          • 1125
          Re: lex x7170
          did you download the print driver from lexmarks website?
