CX510de - white strip
  • lebo
    • Aug 2012
    • 88
    Hello,
    I can not still find caution of printing white strip in black. See the attachment "testpage.pdf".
    For example switching between text mode and text/picture mode during copying makes strip less or more visible.
    There are new image units in the machine. I also tested them in another machine, they worked ok.
    Transferbelt was changed a 4 months ago.
    I also cleaned mirror and glass in laser unit.
    What do you think, is it damaged laser ?
    Thank you for your advice.
    Re: CX510de - white strip
    Originally posted by lebo
    Hello,
    sounds like you have toner clumps in the dev unit... replace dev powder or whole unit
    • lebo
      • Aug 2012
      • 88
      Imaging-Developing unit is OK. I tried imaging units (all tray with all units and toners) in another machine and it worked without any problem.
        • 22996
        Take a look at the black drum unit. I've seen a bit of foam packing get stuck in the laser path. It's not particularly noticeable until you run the test sheet. =^..^=
