lexmark c4150 please wait
  • slot
    • 341
    Im looking for some help with an lexmark c4150 that when you power up it will get halfway into loading up then stops with busy please wait on the screen .
    we are mainly aricoh dealer and have been selling lexmarks for a few years and never had this problem.
    any pointer please.
    Re: lexmark c4150 please wait
    any pointer please.
    so does it kick an error?
    what have you done?
    1st thing to try on ANY unit that is doing this:
    1) pull all wire harnesses of the boards and reseat
    2) flash firmware.
    3) check life of consumables... replace and that are needed.
    • slot
      • 341
      thank for the reply the printer is only a few months old so the parts are all still new .
      there are no error cods it just gets half way through loading the screen and stops saying busy please wait i will get a good look at it in the workshop tomorrow if needs be i will contack Lexmark help desk and seeif they go down the board route.
      • dalewb74
        • Feb 2018
        • 1132
        unplug any cables on the back like usb and network cables. then reboot and see if it will power all the way up then.
          • 22999
          what have you done?
          2) flash firmware.
          Not listening? =^..^=
            guess not.. but like most.. " must be a board"
            • dalewb74
              • Feb 2018
              • 1132
              are you able to boot into the diagnostic menu? sometimes you can do this when it won't load the normal way.
              • slot
                • 341
                sorry guys I don't have an answer for this problem all I can say is Lexmark has had a problem with the error and had no answer so exchanged the machine.
                • Arcadian
                  • Feb 2010
                  • 218
                  any pointer please.
                  change the fuser, or hvps. seem not coming up the proper way of booting.
                  please wait for warming up, or checking the temp. also i had the side door have this issue, printhead problem, (laser cable) broke.
                  good luck
                  • redzventures
                    Service Tech
                    • May 2009
                    • 45
                    Seems as though removing all connectors on the controller board and re-seating would be an idea. You won't be able to flash firmware if the machine is not in a ready state unless it shows up on the network and the web page displays (unlikely). Also as a previous poster suggested, removing all network connections and trying reboot again.
                    Controller board comes to mind on so many Lexmarks.
                    • ktucker
                      • Apr 2012
                      • 23
                      did you find the fix ?
                      I have one doing the same thing
                      • Arcadian
                        • Feb 2010
                        • 218
                        its was a cable for me, if i recall, i do not quite remember which though, one of the cable molex had a bad soldering point on the mother board, had to double check the soldering, i would jimmy rig the side door then touch the cable or motherboard to get an idea where the break will be. but most definitely its the main board.
