Lexmark XC9235 / XC9245 Drum Reset
  • tsbservice
    Field tech
    • 8007
    Re: Lexmark XC9235 / XC9245 Drum Reset
    So, you are not worried about replacing drum/s over life? But just for a message?
      Wrong, these are like the Konica Minolta drums they go twice over life without any copy quality issues. And they definitely wont cause jamming as you suggested
      Jamming will come from worn feeds that are also pm parts. What about drum gearing? That will surely cause issues, jamming also.
      Does the dev unit last 2 times also?
      I don't condone trying to double life of parts. But if you keep it clean, most times you could get more out of it.
        • 8142
        • Southerner
          • Oct 2019
          • 13
          #19
          Hi guys, just wandering whether anybody found a way to reset these drums
          im aware you can switch of the notifications on the EWS
          Seemed crazy to have to replace them when there working perfectly ok
          • adoug
            • 23
            #20
            setting it to snmp only or change the drum chip
              • 8142
              #21
              Can you go into more detail please "snmp only?"
              We want to disable the drum life warning & monitor the print quality manually during maintenance visits.
              • dalewb74
                • Feb 2018
                • 1150
                #22
                as stated before, to reset it you need to replace the drum. that will reset the message.
                  • 8142
                  #23
                  No sugar Sherlock !
