Lexmark XM 7155 white lines
  • deputydogg
    • Nov 2015
    • 172
    The machine is putting white lines from lead edge to trail edge. I just replaced the drum unit 3 weeks ago for the same problem. I've since been told to replace the system board, power supply, transfer roller charge block, and drum at the same time. Has anyone seen this ? Is there a way to determine which part it actually is ?
    Thanks,
    Dave
    Re: Lexmark XM 7155 white lines
    Thanks,
    Dave
    are you sure nothing is blocking the LSU?
    did you measure voltage on the drum/transfer contacts?
    what are the Life left of the supplies/parts?
    you did vac out the entire machine and clean LSU glass?
    upload an example?
      [QUOTE=Phil B.;821018]are you sure nothing is blocking the LSU?
      upload an example?
      are they using genuine OEM supplies?
        • 22929
        If Lex toner cartridges sit on the shelf too long you can get mottling where the seal contacts the developing roller. Dry wiping the developing roller usually solves this. Certain models are easier to get to the developing roller than others. =^..^=
        • deputydogg
          • Nov 2015
          • 172
          OEM supplies.
          Drum/Toner are both over 75%.
          The problem goes away after installing new drum.
          • deputydogg
            • Nov 2015
            • 172
            [QUOTE=Phil B.;821019]
            upload an example?
            OEM supplies.
            The problem goes away after installing new drum.XM7155.pdf
            • Pafasa
              • Sep 2019
              • 14
              It sure looks like the symptoms created by dirty Laser Slit Glass. Like Phil suggested, have you vacuumed out the machine and cleaned the laser?
              • deputydogg
                • Nov 2015
                • 172
                I have vacuumed it out but have not cleaned the laser. I would think if the laser was dirty it would not change the print quality when I put a new drum in.
                • Pafasa
                  • Sep 2019
                  • 14
                  I totally agree with your logic, but I have seen stranger things. It only takes a few seconds to check. Run a q-tip back and forth in the laser slot. see what comes out on the q-tip.
                  Another thought is the drum/imaging unit is failing prematurely. possibly due to bad toner or too much heat inside the machine?
                  • Lance15
                    • Jun 2015
                    • 1073
                    Check this thread on the reliability of Lexmark drums:
                    Faulty Lexmark Imaging Units.
                    • Pafasa
                      • Sep 2019
                      • 14
                      Thanks, lots of info in there that possibly relates directly to the OP's issue.
                        • 22929
                        I'm sticking with my original diagnosis.
                        Another consideration: Since this is monocomponent developing, it only takes a little paper dust under the S-blade to create voids on the developing roller. This was particularly common on Samsung boxes. I've taken apart a few of the Samsung cartridges, but I can never seem to get them back together again. =^..^=
                          I'm sticking with my original diagnosis. =^..^=
                          +1 BC
                          • deputydogg
                            • Nov 2015
                            • 172
                            Here is a photo of the "developer roll" after taking the imaging unit apart.
                            I have cleaned the laser opening with a q-tip with no improvement.
                            Does anyone have the part # for HVPS & System board ?
                            Thanks,
                            Dave
                            • deputydogg
                              • Nov 2015
                              • 172
                              Thanks,
                              Dave
