Lexmark MX410 controller replacement
  • Cirrus
    • May 2008
    • 43
    We went to replace this board and an insert in the package says we need the Service Restore Tool. Is this really needed? I do not want to do the replacement until I know the consequences. The manual also shows only the Service Restore Tool. Is there an optional method for saving and restoring the settings?
    Thanks.
  • Lance15
    • Jun 2015
    • 1086
    • dalewb74
      • Feb 2018
      • 1135
      Re: Lexmark MX410 controller replacement
      service restore tool is built to backup the necessary stuff to import into the new controller board once it has been installed. if you don't, then you could lose some stuff. the service manual should describe the entire process of using said tool. all the one's that i have seen in each service manual does.
