MX421 with broken Start Button
  • i-have-no-clue
    • Feb 2014
    • 14
    Hello,
    I have a Mx421 with a broken Start button. The switch on the panel board is broken.
    Could I use the operation panel from another used machine?
    I've read somewhere that you can't do this with Lexmark machines.
    Thank you.
  • mloudy
    • Oct 2015
    • 773
    Re: MX421 with broken Start Button
    From everything I have been told you can't. I have never tried to swap pwbs in Lexmarks to see what will happen.
    If you can leave a loaner you might try on of these tact switches from DigiKey:
    EVQ-P9W02M
    EVQ-P9102W
    EVQ-P9102M
    TL6330AF200Q
    EVQ-P2602W
    .068 vs. $123.72
    These are surface mount and not easy to replace.
    • Lance15
      • Jun 2015
      • 1082
      The Op Panel on Lexmark's hold critical printer information. Can't replace with a used or refurbished. Must be new so the information can be copied from the systemboard/mainboard (DC Controller).
      • mloudy
        • Oct 2015
        • 773
        A smart designer would have split the part of the pwb with the keyswitches from the LCD diplay. Very stupid design and I think most if not all new Lexmarks are made this way.
          Hey just because an engineer has a degree you expect them to think LOGICALLY? [emoji38][emoji28][emoji1787]
          • dalewb74
            • Feb 2018
            • 1125
            i totally agree with lance on this one. if you don't follow the service manual you can basically brick the copier. good luck!
