XM7355 - Intermittent email glitch
  • arnh79
    • 468
    We recently received a weird complaint on an XM7355 and they sent me a video so I know it's happening as described.
    Customer opens Email app, chooses name from address book, taps Add, and is returned to the original Email screen. The "To:" field is populated with selected email address from the address book. They tap Send and immediately get: "One or more email addresses is required to send an email" - as if the "To:" field is not populated. They have to exit the app and return and then it will work.
    It's intermittent, and seems to have started after upgrading to latest FW. I'm suspecting it's a glitch in the latest FW, but was curious if anyone else is seeing a similar issue?
    Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
    • 23007
    You might try making a new memory location for the email destination. On other Kyoceras, I've had intermittently corrupt addressbook entries that sometimes worked, sometimes didn't. I got the best results from wiping the whole addressbook and starting from scratch.
    • arnh79
      • 468
      That's a good suggestion. Certainly easy enough to try. Thank you for the feedback!
      • dalewb74
        • Feb 2018
        • 1151
        update the firmware. you might also go into the app. stop it then restart it. you could also try a reboot.
