Lexmark Optra T610 with marks on pages
  • Jim Isbell
    There is a regular gray mark appearing regularly on the page about every 3 and a half inches. Sounds like the circumference of a roller. Which one is that size in circumference?
    • 23009
    Probably Fuser Roller
    Here's my formula:
    Circumference/PI=diameter
    3.5/3.14159265 = 1.1140846"
    It could be a drum or a fuser roller, but probably fuser.
    • Jim Isbell
      Thanks, I will check that and see if a cleaning will do the trick.
      • lkrsardis
        • Dec 2007
        • 316
        marks-a-lot
        try removing and cleaning the charge roller and transfer roller with a damp rag.
        Like the United States Postal Service It's a miracle it works!
        • Jim Isbell
          Thanks.
          • Jim Isbell
            You wouldnt happen to know the part numbers of the charge roller and the transfer roller?
              • 23009
              Transfer Roller Part#: 99A0179 or 99A1015
              The Primary Charge Roller is part of the laser cartridge.
              Neither one of those rollers is 1 1/8" in diameter though. Not even close. Cleaning will certainly do no harm, though.
              • Jim Isbell
                Then in the case of one of them, changing the toner cartridge would eliminate the problem. If that doesn't cure it then it at least narrows down the field. Thanks. I think that will help me a lot.
                • Jim Isbell
                  OOPs, no, I miss read your post. You said the Laser Cartridge, not the Toner cartridge. As Gilda used to say......Nevermind...........
                    • 23009
                    Sorry, for me laser cartridge = toner cartidge. Yes, that would rule out out the primary charge roller.
                    • Jim Isbell
                      Great. Because I purchased up a repair kit that has the transfer roller in it...hasn't gotten here yet....and I have several new toner cartridges so as soon as the transfer roller gets here I should be able to test BOTH of them for the problem. And probably cure it.
                      Thanks for all the help. I will report back as soon as its fixed as to what the problem was.
                      • Jim Isbell
                        A new toner cartridge solved the problem.
                        Now, anyone know where I can download a manual for the Optra T610? I need the information on what the various menus do etc.
                          • 23009
                          Include an email address in a private message and I'll send it to you monday.
                          • Jim Isbell
                            Thanks to everyone. I got the Manual, and the printer was fixed by the replacement of the toner cartridge. Nothing else needed.
                            Thanks again.
