ADF-A1 & ADF-D1 parts manuals required
  • Lurch
    • Oct 2007
    • 10
    Hello,
    Can anyone help me with parts manuals for Canon document feeders
    ADF-A1 & ADF-D1.
    Lurch
    • 23009
    Will this due?
    ADF-A1
    1... FG2-1715-170..... DF Controller
    1... FH7-7023-000..... Photoreceptor (S1)
    2... WG8-0164-000..... Photoreceptors (S2, S3)
    1... FH7-7087-020..... Photointerrupter (S4)
    1... RG1-0699..... Photointerrupter (S5)
    1... FG2-1723..... Photodiode (S6)
    1... FG1-8414..... Photodiode (S7)
    1... FG2-1722..... Phototransistor (S8)
    1... FG1-8494-000..... LED (S6)
    1... FG2-1718..... LED (S7)
    1... FG2-1721..... LED (S8)
    1... WC4-0059..... MS1
    1... FF2-0677..... MS2
    1... FF2-4081..... M1, Paper Feed Motor
    1... FF2-4084..... M2, Pickup Motor
    1... FF2-4085..... M3, Delivery Motor
    1... FH7-5159-000..... Brake M1
    1... FG2-1716-000..... Harness from DF to copier
    1... FA3-4683-060..... White Belt
    6... FC1-0313-000..... Plastic Belt Guides
    1... FA5-4655..... Registration Roller
    1... FA5-4656..... Registration Pressure Roller
    1... FA5-4684-000..... Delivery Roller Shaft
    1... FF2-7874-000..... Exit Tray (new style)
    1... FC1-6263-000..... Left Hinge
    1... FA6-5833-000..... Right Hinge
    1... FA6-5839-000..... Inlet Sub Tray flip type
    1... FF2-8069-000..... Inlet Sub Tray new style
    1... XF9-0218-000..... Timing Belt 71T, Front
    Rebuild Parts
    2... FA5-5410-000..... Pickup Tires
    1... FA5-4654-040..... Feed Shaft
    6... 15011368..... or Single Feed Tire (old style)
    6... FC2-1533-000..... or Single Feed Tire (new style)
    6... FA5-5427-000..... Separation Belts
    1... FS3-0135-000..... One-Way Gear 22T
    ADF-C1/D1/E1
    1... FG2-5422..... DF Controller (ADF-C1)
    1... FG2-5480-170..... DF Controller (ADF-D1)
    1... FG2-6485-000..... DF Controller (ADF-E1)
    1... FG2-5465..... S1, Document Sensor
    1... FG2-5449..... S2, Registration Sensor
    1... WG8-5079-000..... S3/S7/S8, Pickup/Upper Cover Frt/Open
    1... FF2-8400..... S4, Delivery Sensor
    1... WG8-5187-000..... S5, Belt Motor Clock Pulse Sensor
    1... WG8-0164-000..... S6, Delivery Motor Clock Pulse Sensor
    1... FG2-5444..... MS1, Upper Cover Switch Rear
    1... FH7-5458..... SL1, Paper Stopper Solenoid
    1... FH7-5286..... SL2, Retaining Plate Solenoid
    1... FG2-5421..... M1, Pickup Motor
    1... FH7-1992..... M2, Belt Motor
    1... FH7-5363-000..... Brake M2
    1... FH7-1994-000..... M3, Delivery Motor
    1... FF2-9470-000..... M4, Separation Motor
    1... FC1-1339-000..... White Belt (15010209)
    4... FC1-7842-000..... Plastic Belt Guides
    1... FC1-7859-040..... Left Hinge (B1?)
    1... XF9-0429-000..... Timing Belt Primary
    1... XF9-0473-000..... Timing Belt Secondary
    Update for loose white belt Drive Belt
    1... FF2-8380-040..... Motor Mount M2, new style
    1... FA6-5862..... Tensioner Roller, new style
    1... FC2-5583..... Tensioner Shaft, new style
    1... XF9-0587..... Timing Belt, new style
    Rebuild Parts
    2... FC1-7768-000..... Pickup Tires
    6... FC2-1533-000..... or Single Feed Tires (new style)
    6... FA5-5427-000..... Separation Belts (15015001)
    • Lurch
      • Oct 2007
      • 10
      Need pics
      Thanks blackcat4866, but I need pictures as well. I have a broken gear in the paper feed section that I need to identify.
      Regards Lurch
        • 23009
        I had to give up my fiche when I left the Canon dealer.
        I'm curious, what gear?
        I've worked on these ADFs for lots of years and only replaced the one-way gear. If you're talking about the one-way gear, it's on the list.
        • Lurch
          • Oct 2007
          • 10
          Blackcat4866,
          I didn't strip the document feeder down enough to get a good look at the gear. I took a photo of it and was going to check it against a parts manual. But I mistakenly deleted the picture.
          I have taken your advise and ordered the one-way gear from your list.
          Lurch
