Can i use vacuum cleaner for suction toner powder?
  • dr.lafo
    • Dec 2015
    • 9
    I have some dilemma about hoover for suction toner powder. Is someone use something like that for suction toner powder? I have this but he is broken and too expensive for repair. Can i use this for suction toner powder, this is much cheaper?
  • copyman
    Owner / Technician
    • Sep 2005
    • 4649
    Re: Can i use vacuum cleaner for suction toner powder?
    I have seen static charge from toner blow up a regular vacuum! Proceed with caution.......
    • exCSER
      • Mar 2009
      • 98
      Household vacuum cleaners are designed to pick up dust. Toner particles are much smaller than dust particles, so the bag/filter in the household vac will not hold toner particles. I've seen quite a mess caused by trying!
      • Iowatech
        Not a service manager
        • 3930
        Also, toner is designed to be moved around by static electricity on purpose. While that can frequently cause toner explosions due to static discharges in the filter in a vacuum not designed for toner, it will cause you to experience a series of irritating to very painful static discharges every time when you vacuum toner with an improper vacuum. Heh, I had to wear my anti-static wristband back in the day to avoid that before we got us vacuums with grounded nozzles.
          • 23002
          Where's the Shop Vac?
          I had a customer at a Best Buy store that called to say that he had installed the third toner cartridge on his Mita DC2585 and it still said add toner! By the time I arrived, he had decided that he would clean up a little for me, and had grabbed one of the nice wet/dry shop vacuums off the shelf, and got to vacuuming. I think he was pretty pleased with himself until he noticed that all that toner had passed right through the shop vac, and had made a nice charcoal gray haze on every surface of his office (if you moved a piece of paper on his desk, there was a clean spot 8 1/2" x 11")(every place I walked left a clean footprint shape). Even the ceiling was covered. It's funny, he wasn't available to talk to me when I arrived to fix the machine.....
          • ZOOTECH
            Senior member of CRS
            • 3375
            I've seen that more than once (and I'll admit that I caused that at least once, when I didn't cover enough area when emptying a DV box).
            • allan
              RTFM!!
              • 5462
              Toner goes thru the filter.
              Melts into the hot bushings and will harden like glue when it cools down.
              But i have seen cheap regular vacuums take a beating for a while.
              3M toner vac stays the best brand i have used with convac a distant second.
              Whatever
              • Alfons
                • Sep 2016
                • 9
                the most important components you already have: the 3M hose and the 3M filter. If fit to any vaccum cleaner you get a powerfull stationery tool.
                • sandmanmac
                  • 3980
                  Hilarious! I could have told nearly the exact same story about one of my clients -with the same old Mita machine too!
                  This took my back a few years
                  • anothertech
                    • 1762
                    Yeah I been there a few times myself!
