KM-1650 Laser Unit needed
    • 22999
    I'm shopping for a laser unit (302C993092) for a KM1650 (same as CS or KM1635, 1650, 2050). More specifically it's the polygon mirror motor that I need.
    Do you mind checking your graveyard? US respondents please.
    Send a private message. =^..^=
    • 22999
    Re: KM-1650 Laser Unit needed
    **bump**
      • 22999
      Yes, still looking. Please check your graveyard. =^..^=
        • 22999
        Still looking. Same as CS/KM1635, 1650, 2050. Anybody? =^..^=
          • 22999
          Do you have any new CS1650 or KM1650 trade ins? =^..^=
          • GIUBOSS
            • 1392
            if you only need the polygonal motor it should be the same as other copier brands
              • 22999
              Yes sir it should. And I still need it. =^..^=
              • JR2ALTA
                • Feb 2010
                • 2031
                Have you called Midwest Copier Exchange?
                Midwest Copier Exchange - Buy and Sell Used Copiers, Printers, Fax Machines
                I bet they would part out a machine for you.
                • occus
                  • 332
                  Do you need the laser unit because you have a error code?
                  Its possible to recover them with cleaning and oil....
                  • tsbservice
                    Field tech
                    • 7981
                    A bit of topic.
                    I think he(BC) knows ALL things inside book and outside, all tricks, tips and workarounds, also a lot of MacGyver thinking. My guess is he is near Copier God than anyone around.
                    The bottom point is...just Laser Unit.
                      • 22999
                      It's loud enough now that the cats scatter when I send prints (preferably less than 10 to avoid the lightening bolt patterns). =^..^=
                      • JR2ALTA
                        • Feb 2010
                        • 2031
                        Is it the "winding down" noise after a copy? I'm surprised you can't lube it. Granted when I did it was much younger than yours but the polygon assy quieted right down.
                          • 22999
                          No ... it's more like the 747-landing-in-your-living-room sound. =^..^=
                          • JR2ALTA
                            • Feb 2010
                            • 2031
                            I can't believe you've gotten over 3,500 views for this 15 year old POS. Move on.
                            • Dickie
                              • Nov 2011
                              • 190
                              I've got a whole scrap machine badged as Olivetti d-copia 16 but am in the U.K
