AR-550U Fuser
  • m.verucchi
    mtech
    • 18
    AR-550U Fuser
    I need the part number for the fuser unit for a Sharp AR-550U
    Thanks in advance
  • travi
    • Jan 2008
    • 129
    The Sharp supply number is AR-703FU1. Order it from supply instead of parts. It is a lot cheeper
    • Marie
      • Aug 2015
      • 7
      Re: AR-550U Fuser
      Travi, what do you mean? Where can I go to "supply" to order parts that I need? thanks!
        • 23010
        Re: AR-550U Fuser
        Sharp dealers purchase supplies from one link, and parts from a different link. Sometimes individual items appear on both. In those cases the supply side is almost always less expensive.
        If you didn't understand the answer you're probably not a sharp dealer, and won't have that option. =^..^=
        • Marie
          • Aug 2015
          • 7
          Re: AR-550U Fuser
          Can anyone tell me: Is the AR-703RC (felt cleaning roller) supposed to be an improvement upon the 700RC oil roller? Can I put the AR-703CR felt roller in my AR-M550U fuser unit? How can I tell if I have a modified fuser or an old model? I also need to replace the 700RC flimsy metal mesh cleaning sheet ("cheese grate"), but it doesn't come with the 703RC kit. Do I really need it? Thanks!
            • 23010
            Re: AR-550U Fuser
            I can't answer all your questions, but I'll answer the ones I can.
            The cheese grater appears only on the earliest incarnations of the fuser. It has been removed entirely. There have been 3 or more versions of this fuser. That's why it's best to get the assembly. Not only do you not have to spend the labor to rebuild your obsolete unit, of which many of the parts won't fit, but also you do not have to figure out which parts will fit which version. The latest version has a web in it.
            Get the assembly. =^..^=
            • Marie
              • Aug 2015
              • 7
              Re: AR-550U Fuser
              Thanks, Blackcat, for letting me know about the difference, but I just spent $300 on new rollers... I need to make do with this old fuser. I'll go ahead and try the 703RC and forego the cheese grater. Thanks!
              • Marie
                • Aug 2015
                • 7
                Re: AR-550U Fuser
                I give. Can you give me the part number for this latest fuser assembly (Sharp AR-M550U/700U)? Thanks, I'd much appreciate it.
