how to get A4 instead of 8 1/2 x 11 paper size ?
  • hugohug
    • Dec 2010
    • 126
    hi everyone
    i have a develop 454e
    when i put A4 paper in tray 1 it shows 8 1/2 x 11 and shows 11*17 when i put A3 and this give me problems when i print i have to select tray manually it doesn't print directly ,
    i appreciate any possible help about this
    thanks in advance
  • emujo
    • Jun 2009
    • 3009
    Re: how to get A4 instead of 8 1/2 x 11 paper size ?
    What county code are you using? Emujo
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      sevice mode marketing area...
      • tech51
        • 840
        Does it recognise the correct size in tray 2? If it does then it's not an area problem but a tray 1 fault.
        In my experience this fault is nearly always caused by a break in the wiring on the tray size (sliding) block.
          • 22619
          Am I missing something here? How about selecting paper tray settings > standard sizes > metric? =^..^=
          • aussieducker
            • Mar 2010
            • 7
            if its only tray 1 reading wrong size, then change out the size detection sensors at rear of tray (the assembly with tray lift motor).
            Had this the other day all other trays correct except tray 1.
            • hugohug
              • Dec 2010
              • 126
              212 morocco
              ok thank you i will try that
              yes in try 2 it recognize A4 ,and in tray 1 it shows 8 1/2 x 11 instead of A4 !
              ok thank you i will try to find tray settings where ever they are
              • allan
                RTFM!!
                • 5435
                Even if the machine is set to metric it will still pick up inch paper. I have a lot of machines with mixed letter size and A4 paper.
                That has its own gremlins. Change the tray out or look for a problem on the tray.
                Whatever
                • filladefilla
                  • Apr 2024
                  • 43
                  I have similar issue with my Konica c454e... Tray 3 is set to 8 1/2 x 11 instead of A4...
                  any help?
                  • Gift
                    • Mar 2011
                    • 2394
                    Check if there's paper behind the tray and if the paper guides are in correct positions.
                    You can also try and swap tray 3 with tray 4 and see if the issues is related to the drawer.
                    • copytechtrouble
                      • Nov 2020
                      • 74
                      any help?
                      if the tray and copier paper size settings are correct but its still showing 8 1/2 in the tray, you may have a broken wire in the PAPER SIZE DETECTION SECTION. I've highlighted the relevant part from the parts manual. there is a Technical document about this failure but I cant find it right now. ill keep looking...
                      • femaster
                        • May 2011
                        • 1361
                        any help?
                        Is tray 3 an LCT? If so, go into service mode, System 2 -> LCT Paper Size Setting -> A4LCT -> A4. Exit service mode, reboot copier.
                        • filladefilla
                          • Apr 2024
                          • 43
                          Yes pls, Tray 3 is LCT, I have set it to A4 yet it still show 8 1/2 x 11
                          pls, advise
                          • tsbservice
                            Field tech
                            • 7512
                            Marketing area?
                            • filladefilla
                              • Apr 2024
                              • 43
                              Thanks; it's working now. I also had to go to LCT's built-in Size settings too, to change it to A4.
                              Thanks so much femaster
