I got a couple service calls of 951 recently ,all had the same problem-the image was blurred in some area.I changed the drum ,the problem solved.But the problem came back after few weeks .The life of the drum is just 20k to 80k.Any suggestions about this issue ?Thank you very much!
951 blur image
Re: 951 blur image
More likely some a foreign contaminant causing distortion in that case.
If it was toner the image would be lighter in those areas.
Giving every thing in that engine a good cleaning does magic.
How does the mag roller look any scratches or build-ups?WhateverComment
Re: 951 blur image
Like the others have said: between the LED array and the charge grid, that pretty much resolves all quality issues. Do you have a sample of 15% halftone fill? That would tell a lot more. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Re: 951 blur image
Wanted to say that I had this problem a while back and It would come and go. I came to the conclusion that it was a combo of environment(higher humidity) and usage pattern(or lack there of). I checked all of that stuff, charge and LED etc. Ended up being just running a stabilizer in the morning would resolve it.Comment
