Konica minolta C364e - copying from platen glass
  • Kenny
    • Jun 2009
    • 524
    [CQ] Konica minolta C364e - copying from platen glass
    Hi guys,
    We currently have a Konica Minolta C364e in the office that is having issues when copying from the platen glass. The printed copy comes out as if the copy has been burnt?
    we have tried replacing the lamp in the machine and also the CCDB. The machine is on the latest firmware.
    Any ideas would be much appreciated.
  • allan
    RTFM!!
    • 5462
    Re: Konica minolta C364e - copying from platen glass
    Try pulling the front left corner of the scanner up while making a copy.
    Make sure to follow procedure when physically changing the CCD out. You don't want to loose the factory position...
    Whatever
      Originally posted by Kenny
      Hi guys,
      has the machine been tipped over or fallen?
      looks likes mirrors are out of whack
      how many scans/total pages on it?
      a certified tech worked on it?
      • tsbservice
        Field tech
        • 7979
        May take some measures tomorrow from office machine, but as others said check front left scanner side for being bend down.
          • 22999
          Like the others have said, its a focus issue. =^..^=
            • 14521
            Does it do the same through the DF?
            • Kenny
              • Jun 2009
              • 524
                • 14521
                So, something is happening as the scanner moves down the rail. Remove the glass and manually slide the scanner down the rail and see if it moves evenly (unplug machine first)
                • FrohnB
                  • Jul 2017
                  • 1919
                  No obstructions between mirrors and CCD?
                  No "residue" or fogging on one of the mirrors? The Glass?
                  Not sure on Konicas, but is there an Auto Density setting you can turn off to see if that helps?
                  +1 on making sure the Scanner bed frame isn't bent down (front left corner).
                  Same exact symptom (area of problem) with first lamp/CCD and second lamp/CCD?
                  Omertร
                  • Woxner
                    • Jul 2011
                    • 839
                    this is and definetly needed the scanner pulled up on the front left side. if it just showed up this is what i would do.
                    • Kenny
                      • Jun 2009
                      • 524
                      Upon further investigation, i have tried pulling the scanner bed up and the issue seems to change position. The bed must have been bent somehow ???
                      Thank you for your help guys, much appreciated
                      • tsbservice
                        Field tech
                        • 7979
                        Check these measurements and compare with your machine:
