Bizhub454e emulation error
  • patrickjlc
    • Feb 2015
    • 225
    [CQ] Bizhub454e emulation error
    I have this 454e connevted to a windiws pc, that copies fine, can fax normally, but when trying to print it comes up as error. Shows emulation error.
    Machine has been reset to factory by a Konica rep that sold me the machine.
    I tried to reinstall the drivers, using latest available. Firmware has been updated too.
    If it can't print it is as good as a doorstop.
    Any ideas? Thanks.
    Sent from my SM-G930V using Tapatalk
  • Synthohol
    Certified Konica Expert
    • 5840
    Re: Bizhub454e emulation error
    what kind of file? .pdf, .ps, .idd??
    the exact driver name/version?
    printing to IP or something dumb?
      • 23008
      Have you looked at the emulation settings in the printer and in the driver? PCL, PS, XPS?
      If the machine is set to PCL you cannot use a PS driver. Please look. =^..^=
      • mearmi
        • Oct 2010
        • 350
        Any ideas? Thanks.
        Which driver installed? PCL6?
        Try to put on stick and print from the machine as a test..
        Also check the Account Track is off?
