C368
  • hemai2005
    Professional Print
    • 108
    [Jamming] C368
    Hi everybody ,
    I have problem in Konica C368 it give incorrect paper size whatever I set the paper in any trays even bypass ,also I changed paper sizes from letter to 11x17 with all trays but the same message , do you have any suggestion.
    Thanks.
    sigpic
    Learned a lot will become an expert
  • Synthohol
    Certified Konica Expert
    • 5738
    Re: C368
    What size does it think it is?
    If European sizes maybe the marketing area is incorrect.
    More info please.
    Are the trays set to auto size or did someone lock in a size manually?
    • hemai2005
      Professional Print
      • 108
      Re: C368
      Us size,
      All trays Auto, machine detect the size normal but as I said this message happened with all trays.
      sigpic
      • tsbservice
        Field tech
        • 7922
        Re: C368
        Initialize all in System 1 SM.
          • 22937
          Re: C368
          Maybe it would be best if you included a photo of the message on the screen. =^..^=
          • femaster
            • May 2011
            • 1466
            Re: C368
            Originally posted by hemai2005
            Hi everybody ,
            I have problem in Konica C368 it give incorrect paper size whatever I set the paper in any trays even bypass...
            Us size,
            OK, You are contradicting yourself here.
            1. In your first post you state: "[the copier] give[s] incorrect paper size whenever [you] [put] paper in any trays..."
            2. Your second post states: "machine detect[s] the size normal..."
            So which is it, does it show the correct paper size or the wrong paper size when you load the trays? When does this message appear? What is the EXACT wording of the message? Take a picture of the message and post it along with your reply. That would probably be your best option here.
            The only message that I can think of that is even similar to the one you are describing happens when you are trying to print or copy something that is on a paper size (or paper type if a print job) that is not loaded in any of the paper trays. Maybe your problem is not with the trays and it is with the print job or the size detection in the ADF? We definitely need more information if anybody is going to help you out.
            • hemai2005
              Professional Print
              • 108
              Re: C368
              here the attached.
              same screen with tray one or two or three or four with any sizes
              you got my point?
              Thanks.
              sigpic
                Re: C368
                here the attached.
                you got my point?
                Thanks.
                it says SIZE /TYPE what TYPE are defining if PLAIN and your program is set up for something different THAT could be the problem.
                you failed to mention the TYPE in the original message.
                • progoffice
                  • Nov 2008
                  • 334
                  Re: C368
                  Make sure at least one of the 8.5 X 11 paper trays is set to "Plain" paper. It would be odd that all paper trays are set to something other than that, but it's possible to do so. That's the second part of the error message that's often overlooked.
                  • tsbservice
                    Field tech
                    • 7922
                    Re: C368
                    Agree. Sounds like they messed with paper type in all trays even that seems unthinkable.
                    • drowranger
                      • Jul 2015
                      • 122
                      Re: C368
                      Please check if the copier is setup to auto tray selection as well. We usually disable bypass from auto tray selection.
                      Utility>System setting>Auto Tray Selection Settings] Select all trays→[OK]→[OK]
                      i'd also check the tray switching setting while you are there
                      Utility>System setting>Paper tray settings>Autotray switching on
                      Utility>System setting>Paper tray settings>No matching paper > switch tray
                      Lastly ill check if the A4/A3>letter/large switching is enabled at utility>Printer settings>Basic/general settings>[A4/A3<-->LTR/LGRAutoSwitchSetting]→[ON]
                      We always have issues like this due to at least 1 PC at client site setup on different region or they print a email originated from a different region
                      Hope this helps ...
                      • femaster
                        • May 2011
                        • 1466
                        Re: C368
                        Believe me, it's possible, especially in some of the schools we service. It amazes me that some of these people are the ones teaching our children...
                        • femaster
                          • May 2011
                          • 1466
                          Re: C368
                          My office doesn't turn this one on by default, despite me telling them NUMEROUS times to do it during setup. Every time I visit a machine I make sure that I turn it on. It's amazing how many PDF files claim to A4/A3 when they should actually be Letter/Legal. An easily resolved headache that I had stumbled on by accident a few years back.
                            • 22937
                            Re: C368
                            One of my press operators would insist that she NEVER set that tray to 8 0/16" x 12 7/16", yet she was the ONLY operator, only one in the building if you don't count the bus mechanic. And it makes some very strange looking booklets when the paper size is set that way. =^..^=
                            • Synthohol
                              • 5738
                              Re: C368
                              i showed 15 schools how to choose colored paper because 2 colors of paper would false jam.
                              so they set all the trays to color even if there is white.
                              good luck printing for the 10th time.
