Konica c300i error code c6756
  • barber782
    • Aug 2011
    • 279
    Brand new machine just installed at customer. A week of being there it's bringing up error c6756.
    Iv updated the fw, checked the ccd board connections and wiring harness between the ccd and ccd board. Checked the data cable down to mfpb. Reset error. Goes away and comes back a week later.
    Has anyone had an issue like this on the new machines?
    Sent from my VTR-L09 using Tapatalk
  • copier tech
    • 8105
    Re: Konica c300i error code c6756
    Brand new machine, pass it back to KM under warranty?
      • 22937
      I'm assuming that you haven't been present for the errors. If I were to take a WAG, I'd go for the SCDB or the DCPU ... 50/50.
      The DCPU is less work to swap. =^..^=
      • tsbservice
        Field tech
        • 7922
        Run full diagnostic. Reseat all connections of Base board(MFPB), next down the line will be CCD unit.
        Also try to disable CCD Calibration value temporarily(default is ON).
        • erwinf
          • Feb 2016
          • 6
          The B367/C227 also gives a similar fault, resolved the fault by replacing the Flat Cable ( Ribbon) for the CCD unit,
          also does the machine stand near a window, could be that you are getting ambient light affecting the CCD calibration
          • Albonline
            • Sep 2008
            • 1132
            try reseating the board stack. codes in the 60's range generally refer to adf related issues , thus dual scan board ,or radf cis.
            • jwai
              • May 2018
              • 502
              Agree! I had this experience too.
              • ronny2502
                • Mar 2020
                • 77
                Hi,
                are there any field-tested solutions yet? (I mean on new i-series machines.)
                Even in 2025 this error occurs on a ten months old C450i.
                A couple of weeks ago a "trouble-reset" and FW-update was done, now the error occurs again.
                Regards,
                Ro
                • ronny2502
                  • Mar 2020
                  • 77
                  UPDATE:
                  Cables for CCD (AA2JN14500 + A161N14100) replaced.
                  Error remains
                  Next parts to replace: A161N14000 (flat cable) + AA7NH01A01 (scanner drive board)
                  If these parts don't fix it, CCD will be replaced.
                  Ro
