Lexmark Cs-410 White Void
  • Squiggy
    • Jan 2020
    • 39
    [CQ] Lexmark Cs-410 White Void
    I have a white void (see pic)void.jpg in the same area, but only in black. All 3 colors are fine. I've replaced the black developer unit, the entire image carousel, and took out print head assembly to clean mirrors and slit glasses. Has anyone seen this or have any suggestions?
    • 23003
    Re: Lexmark Cs-410 White Void
    The variation in density implies a charge related issue. How about the black drum unit?
    • Lance15
      • Jun 2015
      • 1087
      Are OEM supplies being used?
      It will either be the Black Developer (70C0D10) or the Photoconductor Kit (70C0P00). I can't see it being the Imaging Unit (ITB) since it is only Black that is showing the defect.
      • Squiggy
        • Jan 2020
        • 39
        Yes OEM I have replaced the black Drum unit and developer unit, the entire Image unit out of a pm kit.
        • Drivee
          • Nov 2020
          • 322
          If you replace OPC and DEV, then, something is between laser and OPC. Check laser path..
          • RMC8112
            • Nov 2019
            • 38
            I would check the laser unit. there is probably dirt on the glass or lens. I would also remove the laser unit and clean it that way.
            • techandtrader
              • Jun 2016
              • 330
              First easy thing to do is to wipe the glass! The area is large though and leans towards material breakdown or contamination. Not just some splatter of toner on the glass.
              I have used Canon Imagerunner parts for sale. Most are floor model Color and / Advances Imagerunner with some 3025 3235 parts. Several intact machines being parted.
