Bizhub 458e
  • antone
    • Oct 2014
    • 344
    Bizhub 458e
    Jam code 3003 ...1 or 2 copies out jams and folds entering fuser ! Replaced fuser ect
    Sent from my SM-N981U using Tapatalk
  • tsbservice
    Field tech
    • 7925
    Re: Bizhub 458e
    I would try new paper exit sensor, spring and flag.
    Make sure registration section isn't binding.
    • Woxner
      • Jul 2011
      • 829
      Re: Bizhub 458e
      If the exit sensor does not work replace the clutch on fuser drive or the fuser drive assy.
        • 22943
        Re: Bizhub 458e
        That's it right there:
        Exit photointerrupter or flag
        Exit clutch.
        I've changed a lot of both. =^..^=
        • antone
          • Oct 2014
          • 344
          Re: Bizhub 458e
          Fuser drive....must be a tough 2 replace ( ^^) cat
          • antone
            • Oct 2014
            • 344
            Re: Bizhub 458e
            Think the fuser drive is bad
              • 22943
              Re: Bizhub 458e
              It's similar to the bizhub 554e ... just more things to remove from the rear. I assisted another tech changing the exit clutch a few months ago. 2 hours. =^..^=
              • rrrohan
                • Sep 2011
                • 1977
                Re: Bizhub 458e
                yeah i always just do the assy
