It worked perfectly. He began to print these stripes on the pages. What could be the reason? Could it be black toner? Today I changed the black UI with another - no change.
Bizhub C3110 - black lines on the page?
Re: Bizhub C3110 - black lines on the page?
Can you identify a pattern that it repeats? =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Did you happen to put non OEM toner recently?A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Open the right hand door observe the transfer belt, can you see lines on it? You may need to use a flashlight/torch.
โComment
Yes - i use IT Image toner for Minolta Bizhub C20.this looks like a 2nd transfer issue. look at the transfer belt .see if the image is good or bad. and work forward or backward from there
Image is very good, only this black lines is a problem. Pattern - no repeats.Comment
Attached FilesComment
Hard to imagine it's not the IU - perhaps the ITB cleaning unit isn't doing it's job or you had to make more prints after replacing the IU (guess it was a used one for testing?.Attached FilesComment
You can remove transfer belt unit it's easy but be careful and examine belt surface or even better to stop machine mid-copy and check image on belt.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Now I only cleaned the drum of the black module / with a dry cloth /. I printed 7 pages. The result - the first is good, every next one gets worse.Attached FilesComment
