Konica C368 with error C-3425
  • Tiagocang
    • Feb 2022
    • 62
    hello, got 1 machine with error C3425 i wanna know if i can do something to try to fix this...
    i changed the fuser for check dcpu and prcb problems and with new fuser dont pop the error.... the fuser had 150k+-
    already changed all thermistors
  • femaster
    • May 2011
    • 1469
    Re: Konica C368 with error C-3425
    Use a VOM to check the continuity on the large white connector. Blue wire is common, probe the two white wires and see if the bulb circuit is intact. Perhaps a bulb gave out, or the thermal "fuse" has popped.
    • Albonline
      • Sep 2008
      • 1135
      assuming you in fact cleared the failure?
