URGENT! Invalid card bizhub c203
  • mreu07
    • Apr 2023
    • 10
    Hi there,
    I changed mfp of my bizhub c203 and i recieved error 164. To solve this i proceeded to change firmware, but after i made the card and plugged in the printer it says that the card is invalid.
    Maybe someone could help me?
  • otphas
    • Aug 2019
    • 107
    Re: URGENT! Invalid card bizhub c203
    What card do you use ? How you wrote the firmware to the card ?
    • mreu07
      • Apr 2023
      • 10
      With firmware imaging tool 2006
      transcend 16gb but i reduced to 256mb
      • otphas
        • Aug 2019
        • 107
        16GB is to big will not work , 256mb is perfect , just before write the firmware with image tool , format the card to FAT only !
        • mreu07
          • Apr 2023
          • 10
          still the same error
          • mreu07
            • Apr 2023
            • 10
            or, do you have any idea how to get past the screen with some planets image?
            • otphas
              • Aug 2019
              • 107
              Maybe something is not going ok during writing on the CF card. Did you get at the end message that written is successfully completed ?
              • femaster
                • May 2011
                • 1466
                You need to use an older 32-bit Windows OS to run the Imaging Toolkit software. Even though the software appears to work, it does not work properly under modern OSes and the copier will continue to indicate that the cards are invalid. There is also a really good chance that the card you are using won't work due to it's size.
                About 2 years ago we needed to update firmware on, I believe it was a C253, to try to resolve weird glitches we were having. In the end our IT ended up creating a virtual machine with a Windows XP install before we were able to successfully write a card that the copier would actually accept. I'm sure a 32-bit install of Windows Vista or Windows 7 would have probably worked, but we didn't have installation files handy to install either of them.
                Good luck sir, you are probably going to need it!
                • mreu07
                  • Apr 2023
                  • 10
                  thank you for the tips, i am trying now to install win xp on a virtualbox
                  • Synthohol
                    Certified Konica Expert
                    • 5740
                    wasnt that an indicator of bit sw 10 not set proper? or was that just older machines?
                    i do remember planets or KM logo you set sw 10 to 20 if i remember.
                    Originally posted by KMFLT3CH
                    If you print out a config page it should say Generic 35C-4, which is a C353. You probably have the "planets" screen when booting up the machine, too. This is an easy fix:
                    1. Access the Service Mode.
                    2. Select System 2.
                    3. Select Software Switch Setting.
                    4. Enter Switch No. "10".
                    5. Bin Assignment "00000000".
                    6. Hex Assignment "02".
                    7. Click on Fix.
                    8. Click on End.
                    9. Power the MFP OFF/ON.
                    10. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
                    Generic 20C-4 = C203
                    Generic 22C-1 = C220
                    Generic 25C-1 = C250
                    Generic 25C-4 = C253
                    Generic 28C-1 = C280
                    Generic 35C-3 = C352
                    Generic 35C-4 = C353
                    Generic 36C-1 = C360
                    Generic 35C-1 = C450
                    Generic 45C-2 = C451
                    Generic 45C-1 = C550
                    Generic 50C-1 = C650
                    you can try internet ISW, see guide attached.
                    • mreu07
                      • Apr 2023
                      • 10
                      How can i enter service menu if it s getting stuck on "planets" screen
                      • Synthohol
                        • 5740
                        Isn't there a button somewhere to hold and boot into service mode?
                        Been a long time since I've touched a dinosaur
                        • mreu07
                          • Apr 2023
                          • 10
                          I don t see any button or i don t konw about any
                          • Synthohol
                            • 5740
                            wait, if you hold panel reset while booting will it go into trouble reset mode?
                            if so try stop 0 0 stop 0 1 to see if you can get to service mode from there.
                            • mreu07
                              • Apr 2023
                              • 10
                              I entered in service menu, and i am trying to update firmware via isw
