Hello, i am using the printer in my office for testing purposes and i have an unfortunate case, where after clearing all the data, It will give me an error Code C8403 upon starting. After 30-60 seconds, the printer will restart on it's own to diagnose the problem. This makes it quite annoying, as i have checked all the cables that is responsible for ADF and i don't see any cables being damaged or plugged out. What's even more problematic is in the manual, it recommends looking into ADF in Service Mode. The problem is, ADF setting is nowhere to be seen.
Never had this problem before and it was rarely used. It was only turned on when i needed to test something. I can answer the questions if needed and give more informations as i am running out of ideas on how to make ADF appear in Service Mode.
