Muratec MFX-2850
  • Joer115
    • 6
    Muratec MFX-2850
    I recently went to a job where the client said she needed a new drum installed. I not thinking install the drum and know originally that this perticular machine will automatically detect the drum, well it didn't and I realize when I look at screen that the drum wasn't totally empty it was just saying low, so I got call service 12, I restart machine and clear life monitor and then get call service 11. I talked to muratec and they told me might not be in all the way (the drum) and then others say you can't clear it. I"m at a loss here, it won't let me change any thing or do anything with this error, and when I restart the machine it sees it's a new drum and tries to initialize it but when all done it comes back with the error? any ideas?
  • Joer115
    • 6
    Anyone any ideas?
    • JustManuals
      • Jan 2006
      • 9808
      You may have to wait more than 55 minutes to get a reply. Be patient.
      Paul@justmanuals.com
      • Joer115
        • 6
        ok no prob..was just seeing if anyone was on.
        • copytechman
          • Nov 2008
          • 977
          You need to replace drum and dev @ the same time with that model muratec just like the konica minolta bizhub 200/250/350 series, u can't get away with just replacing the drum alone.. been there, done that. No good... replace dev 2 and run the revelant adjustments as well!
          Regards!
          A.
          • copytechman
            • Nov 2008
            • 977
            As a note, the older model 2830 did have the drum/dev as cust replaceable unit.. but not the 2850, they went to sep/drum dev.
            Regards!
            A.
            • Joer115
              • 6
              wait that I was wrong this is 2830 model you mentioned, it had the drum and developer already in it. so what else could be the problem? Thanks for the suggestion though..
              • copytechman
                • Nov 2008
                • 977
                If it's a 2830, did the machine perform the new drum procedure automatically when u inserted it? Was it an oem dk42830? It should have, all of mine do. Doesn't matter if it says low or empty. It should see it and auto-run the new drum mode (forget exactly what the screen says) and thats all there is to it... otherwise, a possibly defective drum/iu unit.. and muratec should warranty it. (in my opinion).
                Regards!
                A.
                • tech07
                  • Aug 2008
                  • 410
                  error code 12 reset
                  do ...setting * 11....Go to ATDC adjustment...Change value higher..may take a couple of tries to hit correct value range
