Konica 8050 error SC81-01
  • copyplus
    • Jul 2009
    • 100
    The machine was running ok and turned the machine off. Few days later I turned it on and I am getting Error code SC81-01. Will someone let me know what this code means and how I can get rid of it. thanks
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • copycommerce
      • May 2008
      • 65
      Press and hold keys 2 and 5 > Enter data collection > Enter position 11 ( special count ) > Reset counter > Yes > Turn off > Turn on and you should be okay About the code you can check in the service manual AND please don't buy em, you need to search for 5-10 min in theeeeee goooooogle and you will find them free :P
      Have fun
      • Stirton.M
        All things Konica Minolta
        • Oct 2009
        • 1804
        According to the manual....
        81-01
        A printer control ROM software is not installed that is corresponding to the material changeover setting.
        "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
        ---Groucho Marx
        Please do not PM me for questions related to Konica Minolta hardware.
        I will not answer requests or questions there.
        Please ask in the KM forum for the benefit of others to see the question and give their input.
        • copyplus
          • Jul 2009
          • 100
          sorry, I was away from my business for sometime. I just got back and tried 2 and 5 data collection but there is no 11 special count. if I hit data collection, it shows me 5 options for copy counts, radf count, etc and when I hit those option, I cannot change anything. Would someone, please elaborate a little more for me. I will appreciate. thanks
          • Coptech
            worker drone
            • 460
            25 mode, set dipsw 4-0 to 0
            • ebm
              • Apr 2007
              • 183
              To elaborate for you, this error code deals with the firmware or software program written to the circuit boards that control the machine. If you are not a trained technician, you should call one before things get worse.
              It is a serious problem if the error code does not clear by simply turning the main power off/on. Call someone who is trained to repair this equipment.
              • copyplus
                • Jul 2009
                • 100
                would you kindly elaborate little more? How I can find to dipsw after I go to diagnostic mode 2 5. thanks
                • Coptech
                  worker drone
                  • 460
                  Consider the warning given but turn machine on while holding the 2 and 5 keys. When it comes to life, there is a dipswitch mode or memory switch or smoething like that. you want switch 4 bit 0 and set to 0 or Off. I don't know why it would happen out of the blue. Are you certain nobody tried to reflash the machine or swapped a board out of it?
                  • copyplus
                    • Jul 2009
                    • 100
                    No one touched the machine. I turned the machine off and did not use it for few days and when I turned it back on I got error sc81-01. the machine was not even moved from its location.
                    at 2 and 5 I get the following:
                    1. software sw setting
                    software switch setting mode 00
                    01 -- 0 On (1) (If I change anything on this page, it goes back
                    Off (0) 01 and 0 On(1) and off (0)
                    2. paper size 3. pm count 4. data collection
                    5. parts counter 6. password setting 7. telephone No. setting
                    8. M/C serial # setting 9. Indication of ROM version
                    10. some setting (not visible)
                    11. ISW 12.setting date input 13. board change mode
                    I really appreciate the help. I also recognize the warning by emb.
                    I called the technician in June to install the machine. The guy from Konica/minolta in Burnaby, Canada did not know anything about colorforce 8050 and was unable even to hookup the machine and then I have to post on copiertech to get help.
                    • Coptech
                      worker drone
                      • 460
                      the 1st choice is what you want. After that, you will see the screen arranged in 2 separate sections and an on/off selection to the far right. The first group of numbers should use the arrows until it shows 4. The second set should be set to 0 and then touch the off box on the far right side.
                      Again, you are in a dangerous area. Changing other switch settings either on purpose or by accident could cause much grief!
                      If that does not fix it, I would bet that you will have to have someone familiar with the machine and Konica's ISW tool to re-flash the machine and hope for the best at that point.
                      • copyplus
                        • Jul 2009
                        • 100
                        I am sorry, the screen is different than you described.
                        _______ _________ __________
                        | 01 | - | 0 | | On (1) |
                        __________
                        | off (0) |
                        ----------- Numeric key
                        board
                        Arrow Up Arrow Up
                        Arrow Down Arrow Down __________
                        | Previous |
                        | Screen |
                        If you change any value in box 1 or 2 that does not stay and there is no way to turn on or off or reset anything.
                        • Coptech
                          worker drone
                          • 460
                          touch the far left 01 until it turms dark gray, then use the up arrow to change it to 4. then touch the second set of numbers until they turn gray, use up or down arrow until it says 0. Then touch the off button, then you can hit previous screen and turn machine off and on.
                          Again, check and doublecheck the numbers before you make changes!
                          • copyplus
                            • Jul 2009
                            • 100
                            Thank you Coptech. Your instructions were great and I was able to turn on the machine. There is no SC81-01 anymore. The machine is working fine. I really appreciate your kind help.
                            • copyplus
                              • Jul 2009
                              • 100
                              Hi Coptech
                              I need your help once again. I have another problem. I stacked paper in tray one's extra space (about 500 sheets) and loaded paper 8 1/2 x 11 paper in the tray (about 100 sheets) and pushed the tray in. I believe due to the paper in the extra space the tray could not go up and now I am getting add paper sign even if the paper is in the tray. Would you kindly adivse me who to fix this problem. thanks
                              I had 81-01 this morning and I fixed it again with the instructions that you had given me.
