KM Bizhub C6500 Error code C0213
  • goaplus
    • May 2025
    Does anyone have a manuel for this machine that perhaps could give me a reference to the code I am getting.I sure would appreciate it. Thanks in advance.
  • Herrmann
    • Jan 2006
    • 792
    Paper exit issue
    Paper
    exit
    abnormality
    C-0213 After the paper exit pressure
    sensor (PS10) turns OFF, it is not
    turned ON within the specified
    time.
    AC drive board (ACDB)
    Printer control board (PRCB)
    Paper exit motor (M54)
    Paper exit pressure sensor
    (PS10)
    Are you trained on this box? If not, i strongly suggest you to get a GOOD technician. These are Production Printing Mashines, not those fluffy tingletangle color office Boxes. They work very well, if correctly handled, but they will bite you in the arse if you are fumbling around not exactly knowing what you are doing
    If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • RRodgers
        • Jun 2009
        • 1947
        C-0213 (C0213) code intermittently.
        Solution
        PROBABLE CAUSES:
        1.A one-way paper exit drive gear is slipping.
        2. Dirty or failed photosensor.
        Clean or replace PS10 as necessary
        3.Older style regulating shaft is installed.
        HTH
        • seniortech
          • Dec 2007
          • 180
          Had this code many times now, every time it turned out to be a slipping paper exit drive gear ( situated under small cover on exit assy on L/H side of machine) removing gear cleaning shaft and bearing inside gear always has resolved problem.
          • beetle73
            • Dec 2010
            • 44
            You are right! Upgrade the shaft and replace the bearings!
            • oce_cannon
              Re: KM Bizhub C6500 Error code C0213
              Great Thanks for the advice
              • keranali
                • Apr 2012
                • 5
                Do you have a picture of where this gear is ?
                • Arcadian
                  • Feb 2010
                  • 218
                  Yeah where is this gear Im getting this error constantly.
                  thanks in advance
                  • Synthohol
                    Certified Konica Expert
                    • 5738
                    IIRC #11 is the culprit. scuff the shaft where it rides with scotchbrite pad or emery cloth and soak and clean the gear.
                    • swaggen
                      • Sep 2017
                      • 100
                      [ATTACH=CONFIG]32754[/ATTACH]
                      Im having this same error. The paper is not getting through the fuser yet and no where near the exit rollers. Its getting held up before the roller near where the paper comes in and touches the transfer belt.
                      Seems like a motor or the board?
                      • Synthohol
                        • 5738
                        what happens when you duplex? does it only happen on exit on not on turnover?
                        • Arcadian
                          • Feb 2010
                          • 218
                          Okay i found the real problem, there is a coupling that runs the exit roller if that coupling is even slightly misaligned it will throw out an error. i wish i had a picture of it. maybe in the parts book i can show you guys what to look for.
                          Parts - A03U 8617 01 COUPLING /1
                          and A03U 8631 00 Coupling /B
                          Look in the paper exit Guide of the manual
                          OMG!! after changing these two item the machine never stopped!!! Paper would feed crooked and kept goin! I was surprised after changing these parts made a big difference!!
                          but also make sure the exit guide one way bearing is good as well!
                          Good Luck!
                          • swaggen
                            • Sep 2017
                            • 100
                            Synthohol, you are a master of your trade. Duplex produced copies. What direction should I head?
                            • swaggen
                              • Sep 2017
                              • 100
                              Good Luck!
                              Do you think its anything near the exit roller? The paper is still miles away from the exit area when I get this error?
