Bizhub c552 just blow the fuse from the outlet.
  • ReoNeo
    • Dec 2008
    • 25
    Hello
    Can somebody help me with this problem..
    Working with a Bizhub c552, witch are blowing the fuse from customers outlet.
    This happence at once you set the contact in the outlet and push on the main power switch.
    But when you take out the fuser unit, the machine power up as usual.
    But after a while the error code for fuser warm up are shown. As natural since no fuser are in the machine.
    I have no error code from the machine when the fuse blow.
    Hope that somebody know or had heard about this cases on a c552....
  • emujo
    • Jun 2009
    • 3009
    Sounds like your fuser heater coil is shorting. Emujo
    • Albonline
      • Sep 2008
      • 1134
      is the unit on a 20amp circuit?
      • B0265
        • Jan 2007
        • 718
        I have had this once, had to replace both IH power supply and fuser coil.
        • ReoNeo
          • Dec 2008
          • 25
          Thank you folks.
          I have ordered both fuser coil and IH power, and will try this tomorrow.....
          I will replay to you..
          Thanks ;-)
          • ReoNeo
            • Dec 2008
            • 25
            Thanks.
            I had to change both the IH power and fuser coil....
            Thank to you again..
