there's no way its the paper.
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5836
    the proof is in the pudding ma'am.
    BH 951 finisher jams several times a week, callback ratio off the chart until i proved my point.
    WB Mason from Brazil on the left, some cheapo yellow paper i found on the shelf that was several years old in the middle and WB from Indonesia on the right.
    the halfway decent WB on the right was on the bottom of some cases for months.
    but its NEVER the paper right?20160301_095335.jpg same 3HP and corner staple.
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: there's no way its the paper.
    but its NEVER the paper right?[ATTACH=CONFIG]32668[/ATTACH] same 3HP and corner staple.
    But, any copier should be able to feed those papers, right!
    • Synthohol
      • Mar 2016
      • 5836
      thats right, at 95CPM that paper should flow through the machine like a river!!
        • 37513
        Paper on the right appears to have less curl hence less frequent paper jams. Could be as simple as the way the paper is loaded. You may need to take some time at the customer and using fresh packages of paper try running seam side up and seam side down. The way that has the least amount of curl is the way it should be loaded. It could also be the result of moisture if the customer is not loading full reams of paper at a time. Once the ream has been opened moisture can be absorbed by the paper. If the jamming occurs more frequently in the morning than in the afternoon, the paper could be absorbing moisture overnight. Tray heaters may need to be installed.
        • Synthohol
          • Mar 2016
          • 5836
          oh im just poking fun of expectation vs reality when it comes to paper, after almost 18 years turning a screwdriver ive almost seen it all.
          i love this job.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            I have been behind one too many techs who told the customer that it was the paper when they could have fixed something. I always tell the customer if a tech throws off on the paper, make them prove it.
            I had a call on a Minolta Di470 that wouldn't pass a single sheet. The machine was about 4 years old and had a total of about 32,000 copies on it. It belonged to the 18th Corp command. It was in what was the original base hospital, built in 1919. The building has old ventilation system that couldn't be upgraded because the building is a historical site. The command group was always deployed and never there to use it. A ream of paper could sit in the machine for a month or more and this being North Carolina, it is very humid all the time. I showed up with a ream of fresh paper. I explained all about humidity and paper and curl. I put in test mode. It jams every sheet in the fuser. I try 5 times. I remove their paper, install mine and run 50 copies without a jam. I put his paper back in, it jams every page. I put my paper back in and run 50 copies. I put his paper back in and it jams. I ask "do you understand?" he said yes. A month later, probably by the time the ream I left him had soaked up moisture, they called in another work order for jamming all the time.
            • Lagonda
              • Aug 2008
              • 1649
              It took a while and several threats to use a electric cattle prod but we finally taught the field techs not to say "The problems your paper, now stop bothering me, but to say "The problems your paper, now lets see what we can do about it"
              Some of the better techs even keep a ream of good paper sealed in a plastic bag in their car so the can promptly demonstrate to the customer the benefits of dry paper.
                • 37513
                I remember back in he days of coated paper machines and paper pirates. We sold I think it was National Reprographics cut sheet paper and Old Town roll stock. When a customer called in with copy quality issues who had not ordered paper from us for some time, I would take a coupe of reams or rolls of fresh paper with me. I would make a copy on the paper they had, take it out and make a copy on our paper. If ours was good, I would show them the two copies and ask if they wanted to purchase some of our paper or pay to have me adjust the machine with the paper pirate paper.
                  • 23008
                  It was September, a couple (decades) years ago. It had been a particularly hot and moist summer, and the elementary school was not air conditioned. The secretary tells me that some of the colored paper jams on their Mita DC-213re. Machines of that day had a completely horizontal paper path, and if there was any curl, the paper would snag on the drum claws, or the fuser inlet, and jam every time.
                  Then she shows me the wall of colored paper: Eight feet high, twenty feet long, all subdivided into ream sized cubbies ... each cubby with an open partial ream of paper, all different colors, every color that you can imagine. I can't even guess how much paper that might be.
                  After incubating all summer that paper was perfect ... for kindergartners to scribble pictures on, but of no use at all in the copier. If you did get 10 consecutive pages through, it was mostly blank. She was aghast when I told her that the colored paper was not useable for copies. =^..^=
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4710
                    Blaming it on the paper is like blaming a murder on the dead guy
                    Agree there are a lot of differences in quality of papers but I've never been one to blame the paper totally. Many of the old analog copiers had heaters / dehumidifiers in them, or could be installed in high humid areas so we could usually fix the curling from cheap paper. Even most of the copiers today have, or can add heaters for paper drawers.
                    I've had customers near the ocean only call me in summer months, a few service calls in the summer then 8 or 9 months with no calls. Nice contract accounts. (plus get near the beach and see the bikinis )
                    Still like Hammermill paper the best over staples or wb mason
                    • fixthecopier
                      ALIEN OVERLORD
                      • 4713
                      The worst I ever saw was on a Di620. It was August and the air was very wet. They were storing copy paper outside in a storage shed. The paper would pass through the machine and when it came out on the finisher the curl was so bad, it had about a 2 inch gap between lead and trail edge. The copy room was about 8 feet x 8 feet. I had them put a dehumidifier in the room and they were emptying the 1 gallon tank 3 times a day.
                      • theengel
                        • Nov 2011
                        • 1784
                        I just had a paper call yesterday. Color prints were fine, black-only prints came out almost blank. If I ran blank pages through, then sent the paper through again, the black came out fine. Moisture was causing shorts and static sparks. Not real sure what can be done to the printer to fix this problem, other than getting new paper.
                        • fixthecopier
                          ALIEN OVERLORD
                          • 4713
                          One of my military customers found a way to dry paper in the jungle. He took a metal cabinet and put a 40 watt light bulb in it. The heat kept the paper dry.
                          • subaro
                            • Oct 2010
                            • 1274
                            All kyocera floor model mfp comes with two or more storage plastic bags in the tray. below are the description provided in the user manual as to the protection and storage of paper. Lead the horse to the water. If he does not drink, then
                            CAUTION: If you copy onto used paper (paper already used for copying), do not use paper that is stapled or
                            clipped together. This may damage the machine or cause poor image quality.
                            Avoid exposing opened paper to high temperatures and high humidity as dampness can be a cause of problems.
                            Seal any remaining paper after loading in the multi purpose tray or cassettes back in the paper storage bag.
                            If the machine will not be used for a prolonged period, protect all paper from humidity by removing it from the
                            cassettes and sealing it in the paper storage bag.
                            NOTE: Note that some paper types have a tendency to curl and may jam in the paper eject unit.
                            If the output paper scatters or stacks unevenly, turn the paper over in the cassette, or change the orientation
                            (vertical/horizontal) of the paper in the cassette.
                            If you use special paper such as letterhead, paper with holes or paper with pre-prints like logo or company
                            name,
                            • nmfaxman
                              • 1702
                              Back in the analog days, I used to lick down the middle of a fresh piece of paper and just the middle would be light.
                              Proved my point.
