Test chart
  • copyman
    Owner / Technician
    • Sep 2005
    • 4712
    Test chart
    I know I have posted before about not using things for a long time. Like not using meters, vacuums, corona wire, etc. Just realized today I haven't used a test chart but maybe 3 times the whole year. I'll print test pages and use them.
    Does anyone else want to add what isn't being used as much in the copier repair industry anymore, tools, chemicals, etc:
    I'll start the list with has already been mentioned,
    vacuum
    meter
    corona wire
    test charts
    • 23009
    Re: Test chart
    continued:
    Allen Wrenches
    Metric Ignition Wrenches
    Tweaker (for VR's)
    Corona Stringing Tools
    Marvel Mystery Oil
    Fuser Oil (as a cleaner)
    Pledge
    Thickness Gauges (adjusting doctor blade height)
    Pantone Color Bridge
    ColorPic
    • Hansoon
      • Sep 2007
      • 3386
      Re: Test chart
      In the field:
      -Solder Iron
      -IC extraction tool
      -Puller (used them in the very old days to pull off the bearings from fuser rollers. ......and YES I'm THAT old.......)
      Hans
      • copier tech
        • 8165
        Re: Test chart
        Halogen lamps
        • 20 year tech
          • May 2014
          • 577
          Re: Test chart
          Fuses
            Re: Test chart
            Brain.
              • 37520
              Re: Test chart
              Based on some of the questions I see asked here, service manuals.
              • Lagonda
                • Aug 2008
                • 1649
                Re: Test chart
                Clutch end float gauge
                Drum polish
                Door switch cheat
                External counter cheat plug
                Sense of purpose
                • ZOOTECH
                  Senior member of CRS
                  • 3375
                  Re: Test chart
                  A spring/belt push or pull gauge.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4712
                    Re: Test chart
                    Ha-ha great answers! I like the brain post the best. And there is some truth to that with these self diagnostic machines. I remember when there were no codes! You were in a customer's office and felt like you were on a remote island. Probably a good reason for no codes back in those early days was, of course not being digital, but there were no displays to even show a code
                    • Geo
                      • 662
                      Re: Test chart
                      5 minute plastic epoxy.
                      Light activated super glue
                      Paper clips and wooden coffee stirrers.
                      Yellow dusters and canned "air"
                      • gneebore
                        • Feb 2010
                        • 555
                        Re: Test chart
                        Never used canned air after we were shown what happens to circuit boards when hit with a long blast way way back when we were actually repairing early electronic calculators. Yeah they cost over 150 bucks, and labor back then was still less than 30 bucks an hour.. Condensation and fried board was usually the result. Watched a customer use canned air to clean paper dust out of a doc feeder while I was repairing a typewriter. And she blew a few staples into the paper path and she managed to get condensed water onto the photo diode sensors and shorted the doc feeder sensors out. Sure was glad that particular copier was not one of ours.
                          • 8212
                          Re: Test chart
                          Toshiba copiers have test charts built into service mode. I use them all of the time and tell customers this is how I judge colour quality.
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4712
                            Re: Test chart
                            Not sure about canned air not being used as much anymore. I use it almost every call, mostly to blow paper dust off ADF sensors.
                            • techwurk
                              • 127
                              Re: Test chart
                              Hammers, fists and soles of shoes
                              But seriously, there is much less a need of non consumable parts as compared to years ago...
                              When I started servicing copiers they used toaster ovens for fusers.....I'm old
