Any old old school copier techs here?
  • nanohitmen
    • Apr 2019
    • 110
    Was doing some spring cleaning in the shop today when I found an interesting test chart. Did any of y'all use one of these back in the day?
    • 8081
    Re: Any old old school copier techs here?
    ... old school copiers techs are dying off yet many who remain active choose to or have to work well past 65 years old.
    Many younger techs are not interested in keeping older electro mechanical discontinued copiers working ... as it should be.
    Modern copier design is now much more about replacing entire modules rather than spending hours trying to get something to work. You might save a buck on some parts but you spend a fortune in your time.
      • 22927
      Nice find! I'll dig out a few of my ancient Canon and Ricoh A3 charts this weekend. Most of them are so stained you couldn't identify a quality issue if you tried. =^..^=
      • Necrocannibal
        • May 2008
        • 203
        Not sure what you mean by old school but I started doing this in 1990.
        Sent from my SM-N986U using Tapatalk
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3945
            I don't know that I agree it takes less time to repair a modern copier. Why? Because there's a lot more stuff to work on. Lots more adjustments to be made.
            As far as old test charts, I don't have them any longer but I remember them in detail...like they're burned in my brain.
              • 8081
              Many modern copiers print pre-programmed test charts from their system board or HDD. Albeit, there is still a use for techs to carry their own pre-printed paper test chart and a USB drive containing your print drivers and favorite print samples.
              There are still a lot Katun test charts for off the glass still being used especially among techs who work on multiple brands.
                I used the Katun test chart back in the day. Also, I will say that I don't miss rebuilding DV's and Fusers. Don't miss it one bit.
                • gneebore
                  • Feb 2010
                  • 555
                  Way back when I started on the then new Canon pc20 and pc 25's I did a self-paced training course. The training back then on those was in our shop with a vcr and tv to watch the course-movie. And there was a suggestion to use the front page of the local paper. They were black and white and always had some pictures and bold head lines and usually small print. With a slightly grey background of the paper. Made a real good test copy while not quite a chart like we were given when I finally went to a course in NJ for the last of Copystar/Mita analog 25-50 cpm lines and then the digitals which printed their own internal test pages to use as a test chart.
                    • 8100
                    I remember the Canon PC copier we sold so many of these what a great little box, take out the small optic ass'y to clean fit a new UFR & cartridge machine was like new again.
                    Was the PC25 the one with the enlarge/reduce dial?
                    Oh & that little sep belt!
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3945
                      • KenB
                        Geek Extraordinaire
                        • Dec 2007
                        • 3945
                        • tsbservice
                          Field tech
                          • 7909
                          Back in the days when I used Toshiba test chart it was a matter of pride to save your test chart clear and in good condition. Also every additional tinny dot or mark on test chart was burned like map in my mind so when take a copy of test chart I immediately recognized mine test chart 'defects' versus copier added.
                          • gneebore
                            • Feb 2010
                            • 555
                            Had to look them up but yes the box had a dial. Great little machines for light duty. But we had a few customers that ran through three toners in a month. Got so bad with one we had to pick it up off of rental since they did not have a copy count. The rentals for those machines included one toner cartridge every two months. Any more than that they got a charge for extra supplies. Even had one weird customer that insisted we provide the paper she needed to use to make copies on. Because that is a copier supply item.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3945
