Touch Panels once again.....
  • Shadow1
    • Sep 2008
    • 1642
    Re: Touch Panels once again.....
    Just about anything Ricoh from about 4 years ago will eventually fail. They blame it on the adhesive used to hold things together, and there used to be a replacement program. They shipped us thousands of them and wanted us to proactively replace every one of them hopefully before they failed for free - not sure if that program is still active or not, but check the Tech Bulletins for details on any machine with a dead panel.
    73 DE W5SSJ
      • 22999
      No problem.
      VoyagerE:
      Tablet: 302FB25191
      x2 Sponge LCD A: 2BJ25270
      x2 Sponge LCD B: 2BJ25280
      Sheet: 302FZ05060
      Stratos CS-2560
      Tablet: 302H094271
      x2 Sponge: 302H005610
      Stratos CS-3040
      Tablet: 302FB25191
      (how about that ... they're the same as VoyagerE)
      KM bizhub C350
      Tablet: 4037 7807 01
      Can you do anything with the cores? I've got a pile of them on the corner of my desk. I figured that when I got some time I'd give a try at fixing a couple. Well ... I'd better not wait for that. It's never going to happen. =^..^=
      • Hansoon
        • Sep 2007
        • 3374
        No, not at the time. Thanks Cat.
        Hans
        • HughMeares
          #19
          KM-c2525e - I have seen some helpful posts on resolving unresponsive touch panels on this m/c. blackcat4866 suggests removing the control panels, extracting and dismantling the touch panel (aka tablet) and cleaning and reseating. Failing that, he suggests that the tablet sub assy can be rebuilt from the following parts.
          fig 27-27 quantity (1) 302FZ05060 Sheet
          fig 27-19 quantity (1) 302FB25190 Tablet
          fig 27-7 quantity (2) 2BJ25280 Foam Seals
          fig 27-6 quantity (2) 2BJ25270 Foam Seals
          It would assist me if I had a copy of the engineering diagrams in which fig 27 appears and perhaps some images. Also any suggestions about where to source these parts other than through the UK Kyocera network of which I am not a member.
          Grateful for any assistance - Hugh hugh.meares[at]paullhull.com
          • Hansoon
            • Sep 2007
            • 3374
            #20
            Hugh you have mail
            Hans
            • mojorolla
              The Wolf
              • 2599
              #21
              Panasonic DP-8035, 8045, and 8060. Also DP-2330, 3030. They both use the same panel; #DZTE000044R.
              • Hansoon
                • Sep 2007
                • 3374
                #22
                Guys, the Touch Panel for the KyoceraMita KM3050 crosses to what please?
                Hans
                • Masterchief
                  • Apr 2011
                  • 280
                  #23
                  Originally posted by Eric1968
                  Ricoh MP C2000/C2500/C3000/C3500/C4500 : B223 9900
                  Ricoh MP C2800/C3300/C4000/C5000 : D029 9900
                  Ricoh MP 2510/3010/2550/3350 : H310 9900
                  Ricoh MP 2250/3350 : D009 1488
                  Eric
                  Ricoh MP 2510/3010/2550/3350 : H310 9900???
                  Eric i taught the H310 9900 only worked on the 1035/1045/3035/3045 range and the newer 2550/3350 took D009 1488 Operation panel mod
                  Maybe i was giving the wrong info from Ricoh
                  Masterchief
                  sigpic
                  • Hansoon
                    • Sep 2007
                    • 3374
                    #24
                    * cough *
                    Hans
                      • 22999
                      #25
                      Sorry for the delay Hans. Actually, in 5 years I've never changed one, but we know that there are environmental factors that make them fail sooner. FalconIII includes: CS-3050, CS-4050, CS-5050, KM-3050, KM-4050, KM-5050.
                      302GR45040 Tablet
                      302GR05310 Sponge LCD A
                      2BJ25280 Sponge LCD B
                      Only FalconIII machines AFAIK. =^..^=
                      • Hansoon
                        • Sep 2007
                        • 3374
                        #26
                        Thanks Cat!
                        Hans
                        • Hansoon
                          • Sep 2007
                          • 3374
                          #27
                          Eric
                          Masterchief
                          Now I'm confused. What goes to what?
                          Also, do all of the above touch panels have the same failure rate? Which one would be the most important to have in stock?
                          Hans
                          • lorenzo
                            • Dec 2008
                            • 20
                            #28
                            Originally posted by Hansoon
                            Not responding touch panels often can be repaired as long as the problem lays in the connection of the flat ribbon cable.
                            However, many customers irritated by the non responsive Touch Function use excessive force and sharp objects such as pens to operate the panels. Furthermore some of our colleagues try to revive not responding Touch Panels by putting them in an oven at high temperatures. This all results in invisible damage to the thin plastic foil on top of the glass pane making a repair impossible.
                            For this reason we intend to supply in the future brand new aftermarket Touch Panels in such cases where repair is not possible anymore.
                            To offer a complete assortment for as many models we like to know once again which models from what manufacturers are suffering from not responding Touch Panels.
                            Kindly post here the manufacturers name and model knowing to have been affected.
                            Many thanks in advance
                            Hans
                            touchpanel[at]rex-technika.com
                            nashuatec DSm745 & MP4500
                            • Hansoon
                              • Sep 2007
                              • 3374
                              #29
                              Cat, a customer complained that the touch panel for the KM-3050 is not fitting in the KM-5050. Are there different versions perhaps?
                              Thanks.
                              Hans
                                • 22999
                                #30
                                According to the manual, no, they're the same. But like I say, I've never needed to change one.
                                What's more likely is that they either can't fit it due to inexperience, or it didn't fix the problem they were trying to fix (like an op panel firmware issue). =^..^=
