The random thought thread
Re: The random thought thread
Killdozer? Not quite. More like Soylent Green's riot trucks.
Open the links at your own peril.
Still, MUAHAHAHAHA!Comment
Still, MUAHAHAHAHA!Here's a YouTube of the thing. You only need to watch it halfway though, as it starts over then (when you see the donuts for the second time).Comment
Space X launched a rocket recently that had their first recycled first stage. I got to see most of the the feed of that flight.
Also, the lounge area that used to be on Boeing 747s. I've only been on a 747 once during the flight back to CONUS from one of the humanitarian missions while I was probably in the Reserves. It may have been a cargo conversion (it was an Evergreen Airlines aircraft, and if I am wrong I sincerely apologize!), but since there was only several hundred people on board it was a fairly pleasant flight. So if fate and circumstances allow you to travel on a 747, I encourage you to consider it a positive thing.
Finally, if you are in the northern hemisphere and the sky is clear, you might look for the Fool's Comet Comet 41P/Tuttle-Giacobini-Kresak. Theoretically it should be visible with binoculars in the northern sky now, but the link will have some coverage of it too.
As always, open the links at your own peril.Comment
Isaac Newton says we can't have flying cars? Aw...
Well, if that's the case, this will do:
Remember when you were young and would just leap over small fences with no effort?
The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
http://i.imgur.com/cA3Gu9z.mp4Comment
How to turn an enemy into a friend.
Also, actual science on why shoelaces become untied. I always tuck the loose ends in between the tongue and the upper, so most of the time I don't have that problem. It looks less sloppy that way too.
Speaking of shoes, you ever notice that some of the cheaper ones have ridiculously long shoe laces? Wal Mart used to have some cheap but decent looking shoes that were pretty comfortable and had a facsimile of the Vibram boot sole that worked well enough in the mild winters here. But the shoe laces were long enough that I could have used them on my steel toed boots that I had to keep in the car because OSHA.
Heh, the time I went to Fort Leonard Wood, the support shop we were working in made us wear corrugated metal covers on our boots. We affectionately nicknamed them moose lips.Comment
http://i.imgur.com/cA3Gu9z.mp4' "But the salesman said . . ." The salesman's an asshole!'
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
