Which copier was the biggest piece of crap ever?
  • patterson
    • Dec 2006
    • 30
    #136
    Could you expand on that?
    Tonerbomb, could you give me a few examples on the problems you are having withthe Savin 2408/3210? I have sold several in the field withlittle problems, but theay are not getting overused, could that be the diference?
    • rocket
      #137
      Analog Minolta 4230. Nightmare when it came time to clean or repair clutches, which was often in this machine. clutches were between the rear main frame and a sub-frame metal plate.
      • lkrsardis
        • Dec 2007
        • 316
        #138
        pos
        The Mita 213, you gotta love the scanner clutch pack. Also the Ricoh ft 6085 and all of it's spawn, the inverter gate adjustment was an art not science.
        Like the United States Postal Service It's a miracle it works!
          • 22932
          #139
          I changed a few of those DC-213 scanner clutch springs. Typically I had to take it apart a second time to get everything back in place just right.
          Now the DC-111 & DC1205 clutch packs: I had that down to a science. One hour to rebuild, worked right the first time, every time.
          • lkrsardis
            • Dec 2007
            • 316
            #140
            pos
            Blackcat your a better man than me, I finally stopped having the night sweats over the older Mita's.
            • tufbnme
              • 493
              #141
              Any old Pitney Bowes junk
              How about any of the old Pitney Bowes models before they went to Ricoh. Even the old Ricoh oil pumpers!
              • lkrsardis
                • Dec 2007
                • 316
                #142
                pos
                I forgot about the Ricoh ft4060 and the FT5520 which was the only machine that i know of that the class for the mods.was as long as the original training class.
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  #143
                  Originally posted by Anders Nilsson
                  To me it must be Ricoh Aficio color 2003 without any hesitation
                  AGHHHHHHHHHHH, you had to book a day to service that machine, and 2 if you had to change the dev................
                  The gene pool could use a little chlorine.
                  • Travis06
                    Tech.
                    • 193
                    #144
                    E-studio 3511 / 4511
                    • vincent64
                      • 382
                      #145
                      Sharps, most all I work on...
                      Anything that takes SF-216 supplies, struts on these things aways going bad, just locked vise-grips to the rod to keep it open.
                      The old SF-7700 bunch, and the old SF 7800 group of copiers.
                      The newer AR bunch, the AR 200, pain in the rear to work on, back has to come off to work on it for most anything, and way too much plastic, fuser unit mounts into a plastic frame, this is a unit that heats to 190 deg C, and mount into plastic, yepp,,,real good idea, LSU a pain. and feed rollers, take out all supplies and turn on side.
                      Somebody else said if not for some of this we would not have jobs, wrong, as my SM says, "You cant fix stupidity."
                      • Jason
                        #146
                        KM C6500
                        Registration front to back is terrible. Service plan through CBS out of Connecticut was the worst. I strongly advise not using CBS for your service company. They took 2 weeks to show up for service calls. ordered wrong parts, sent the wrong toner...ect.
                        • iMind
                          Vacuum Cleaning Expert
                          • Mar 2008
                          • 1116
                          #147
                          RICOH FT-5520 a nice day going paranoid add toner with full toner bottle, Hehehehe
                          • rambo40
                            • Oct 2007
                            • 21
                            #148
                            Originally posted by cmb
                            how about the konica 1503, 2803, 4290, and any and all clamshell models. the new stuff is allright.
                            The canon irc3100 and irc 6800 both are CRAP.Labor intensive etc
                            • 11x17
                              • Apr 2007
                              • 153
                              #149
                              I'll second rambos vote for the 3100 but ya gotta love the 6800 series if you are under the BEI system and know what to look for.
                              • DocF
                                Old Retired IKON Drudge
                                • 41
                                #150
                                Originally posted by jcirafic
                                To GAlexander, no I don't remember the 9040 but I remember the 700 series, 5030, 5040, 7030, 7050, v-35 (color copier, 3 liquid toner colors), v-45 and I know I'm forgetting a few. These were brutal, sounds like you worked on them too. Any powder machine was heaven compared to them. I remember rebuilding the pumps after cleaning them in a parts washer. Talk about going thru hand cleaner.
                                The Savin LTT machines were tanks. We had about 1000 7350s out in a school system. We did one PM a year, pulled out a paper jam once in a while and they just flat ran. Rubber gloves and diapers were part of our tool kit. I still use them. The kids I work for now think that's funny, but they didn't have to deal with those.
                                Actually, I've worked on almost all of the dogs listed here. My vote goes to the Savin 300 roll plain paper copier. No other machine had the frame replaced by the factory. This turkey had retrofits for the retrofits. There were hand wired machines, printed circuit machines, but none of them would tone up properly, none had a fusing unit that would work for more than a week and none would advance the OPC belt properly. We had 39 of these out at one time. We needed three techs to keep them running.
                                Second place goes to the Apeco Super Ultra Stat. We used to stand in the showroom window and watch the poor suckers who sold that pig go out from the branch across the street and laugh. It took an average of 45 minutes to remove a paper jam from the squeegee rollers.
                                Third place is the infamous Savin 840 electric footstool. They leaked, squeaked, and streaked. One of my service managers went to Wal Mart and bought jelly roll pans to put under all the ones they had out to contain the leakage.
                                Fourth place is the Ricoh 5560. This thing was so bad Ricoh offered to buy them all back.
                                Doc
