Need help please noise comming from doc feed
  • neergish
    • 177
    "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: Need help please noise comming from doc feed
    Originally posted by neergish
    [ATTACH=CONFIG]29084[/ATTACH]
    You better get that thing off of there! Believe me, they do not need help making copies of themselves. I Know!
    • Exok
      • Jun 2011
      • 750
      That must be the infamous Copy Cat.
      • emujo
        • Jun 2009
        • 3009
        Reminds me of one of our accounts...small print shop, the owner is a greyhound racer and saves retired dogs (which I applaud her for). To get to the machine you have to navigate through 6-8 retired hounds, some are friendly, some are skittish, so every time you move you either have a dog running away from you, or coming over to get a quick pet. Also 2 cats that seem to want their share of attention just when you've set those 1/2 dozen screws down on the counter and they are up and kicking things around. Every call is 30 min of removing animal hair and dander. And the owner is no help, she just sits there and marvels about how wonderful her animals are. When you leave, it's the same obstacle course of dogs and cats, and another 10 min of removing hair from every orifice and clothes. At least they aren't barking the entire time, that would drive me nuts. Emujo
        • gwaddle
          • May 2009
          • 782
          I think it's quite rude to have animals in an office and expect everyone to just adjust to them. I don't hesitate to let the animal know that I'm not their friend. If I could refuse to go to those calls, I would.
          I know I should be ashamed of myself. Strangely though, I am not.
          • ZOOTECH
            Senior member of CRS
            • 3375
            No help needed here, machine is working purr-fectly.
            • allan
              RTFM!!
              • 5462
              hehe, just press start for a CATscan.
              Whatever
              • anothertech
                • 1769
                I've had my share of mice damage in machines, they like to chew through the wire bundles, I think your protected from the mice on that machine!
                • allan
                  RTFM!!
                  • 5462
                  An Oce 3165 should come standard with a cat.
                  Whatever
                  • CraigW
                    • Dec 2010
                    • 417
                    I read where some manufactures (auto, & maybe others) started using soy based materials for wiring insulation.
                    That was a well thought out idea.
                    • copydocinc
                      • Mar 2015
                      • 263
                      That's a DOG gone CATastrophy. Use FISHoil to get rid of the squeak
                        • 23007
                        It sounds fine to me. =^..^=
                        • Tonerbomb
                          AutoMajical Resolutionist
                          • Feb 2005
                          • 2589
                          How obvious could this be ???????????
                          Mystic Crystal Revelations
                          • fixthecopier
                            ALIEN OVERLORD
                            • 4713
                            We have a customer that does accounting in her home. She has a Ld016, and about 6 huge house cats. I had a call for document feeder jamming. One of the cats was on top of the adf. I lifted the cats rear up, put some papers in and they fed. i told the lady that her problem was that she must have been putting the documents on top of the cat instead of under it. She was amused, however the cat was not when I moved him to an Epson printer while I changed rollers.
                              • 23007
                              Who's the babe? Can you introduce me? =^..^=
