Database Errors
  • tsbservice
    Field tech
    • 7955
    Re: Database Errors
    Originally posted by Aneurysm
    OK I found something, working much better for me now, how is it on everyone else's end?
    It works now. Thanks for your time and much needed input. Keep up the good work.
    • guitar9199
      • Sep 2016
      • 1099
      Re: Database Errors
      I'm in!! Thanks brother!!
      Have a Happy Thanksgiving!
      • NeoMatrix
        Senior Tech.
        • 3514
        Re: Database Errors
        The database purge appears to have worked.
        Re. Database fault.
        Was it a temp table dataset(AKA dead file) that didn't merge with the primary database?
        Maybe semaphore flag holding the primary data set locked?
        Could it be duplicate primary key or out of range variable fill with corrupt characters?
        Corrupt data can prevent the main database from updating.
        It appears you have fixed the fault, well done....
        • Synthohol
          Certified Konica Expert
          • Mar 2016
          • 5782
          #19
          Re: Database Errors
          YAYYYYYYYYY!!!
          • 20 year tech
            • May 2014
            • 577
            #20
            Re: Database Errors
            working like it should, well done thank you
            • driving lots of miles
              • Jun 2016
              • 397
              #21
              Re: Database Errors
              working normal now even the new posts button is working again.
              thanks!
              • copyman
                Owner / Technician
                • Sep 2005
                • 4599
                #22
                Re: Database Errors
                Thanks aneurysm. Hopefully it's fixed and you don't have to be messing with this during the holiday weekend!
                Working great! Seems faster or maybe just because I haven't been able to get on in about a week
                Happy Thanksgiving to everyone.
                • Aneurysm
                  Administrator
                  • Jan 2005
                  • 1030
                  #23
                  Re: Database Errors
                  Re. Database fault.
                  One of the tables in the database had a very large chunk of corrupt data, it should have self-corrected but I think due to the size of the bad data it was taking too long to repair and that brought on the timeout errors. Had to fix it from the Server/SQL side, hopefully that will take care of it.
                  • Aneurysm
                    Administrator
                    • Jan 2005
                    • 1030
                    #24
                    Re: Database Errors
                    Seems a little faster to me too
                      • 22990
                      #25
                      Re: Database Errors
                      Thanks! I was getting worried. =^..^=
                        • 37194
                        #26
                        Re: Database Errors
                        Thanks Aneurysm, some of us were starting to worry about you.
                        • mansart
                          • 852
                          #27
                          Re: Database Errors
                          Thumbs up.....aneurysm
                          Now for the "put your money where your mouth is" statement........
                          Would be nice to see a few new "Contributor" badges
                          • Zaxxon
                            • 608
                            #28
                            Re: Database Errors
                            Great admin, thanks
                            Please start you post with brand, model, problem.
                            • keithxxiii
                              Just a tech
                              • Nov 2014
                              • 468
                              #29
                              Re: Database Errors
                              Awwww Yisssss!!! We're back!
                              Aye! Cut the crap
                                Re: Database Errors
                                AWESOME Job Brother! Working correctly on my end also!.. will be contributing again!
