Compressed Air
  • adamcopiercali
    • Aug 2012
    • 88
    Compressed Air
    Hi,
    Was wondering where you guys get your canned air from? Recently it has been harder and harder to find locally at a reasonable cost. What brand/s do you like best? And where do you buy from?
  • Hart
    • Feb 2024
    • 411
    Re: Compressed Air
    And bonus question, did anyone tried an electric air duster and is it compact enough to carry in the toolbag ?
    • mloudy
      • Oct 2015
      • 787
      Re: Compressed Air
      Image Supply Service
      6000SP 10oz.
      We have been using this product for years.
      A big NO to the electric duster we tried. Very loud.
      • tsbservice
        Field tech
        • 8019
        Re: Compressed Air
        Originally posted by adamcopiercali
        Hi,
        Where is that location? On the Mars?
        It's simple supply.
        • Hart
          • Feb 2024
          • 411
          Re: Compressed Air
          More than the toner vacuum ?
          If I could simply plug it in my trunk to recharge instead of tracking each time how many cans are left ...
            • 23008
            Re: Compressed Air
            Air with refrigerant? NEVER.
            I've frozen too many sensors. The refillable bottles that can be filled with a compressor are better, silent, and never froze a sensor. Next choice: blower brush. =^..^=
            • anothertech
              • 1771
              Re: Compressed Air
              I like the idea. Only $20 US on Amazon.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4709
                Re: Compressed Air
                I've tried those refillable air bottle and they are good for some light dust but not much more. Nothing better in my opinion then good old canned "compressed" air. There are some cheap compressed air that produce ice even when not tilted. They all produce ice when can is turned upside down, that's just the nature of compressed air. Best I've found is Stoner Gust and Uline canned air. A little pricey but a valueable "tool" which I use almost every service call.
                • ZOOTECH
                  Senior member of CRS
                  • 3375
                  Re: Compressed Air
                  Originally posted by copyman
                  I've tried those refillable air bottle and they are good for some light dust but not much more. Nothing better in my opinion that good old canned "compressed" air. There are some cheap compressed air that produce ice even when not tilted. They all produce ice when can is turned upside down, that's just the nature of compressed air. Best I've found is Stoner Gust and Uline canned air. A little pricey but a valueable "tool" which I use almost every service call.
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4709
                    Re: Compressed Air
                    Originally posted by ZOOTECH
                    Just be sure that there are no flammable contents if using a toner vacuum to suck up the debris.
                    I found out by experience after a rather large ‘fart’ and flame from the exhaust of the vacuum.
                    No injuries or damage other than my nerves.��
                    Good advice. Fortunately using canned air helps me limit using the vac. I've probably only used the vac about 2 times in last year. Not saying only the canned air helps with not using vac, mostly because the new machines run so much cleaner.
                    • ZOOTECH
                      • 3375
                      Re: Compressed Air
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4709
                        Re: Compressed Air
                        What I meant was the Kon/Min new style models from last 10 years don't need much vacumming. "4" series to present
                        • Hart
                          • Feb 2024
                          • 411
                          Re: Compressed Air
                          Same for Sharp, the CR4 CR5 series are really clean, I don't use the vacuum a lot now.
                          • ihatefinishers13
                            Senior MFP Technician
                            • Feb 2020
                            • 707
                            I currently have this https://a.co/d/epeyxKq and would recommend it, but yes, a little loud.
                            I would NOT recommend https://a.co/d/hjf6rOj as it is HUGE. That being said, I would love this in a woodworking setting. Super powerful, and has a nose included.
                            With the canned air, we've put together flexible hoses so you can keep that can vertical, and get to almost any small location/sensor.
                            • Vincent128
                              • Sep 2015
                              • 349
                              Currently we use this
                              Amazon.com : xpower a 2
                              Love it !
