Canon NP 1215 not printing
  • tarnation
    I have an old Canon NP 1215 copier.
    Its not printing, white paper, no image at all.
    I've installed a new cartridge, paper path seems fine.
    Hasn't been used for a while.
    I've done the basic maintenance routine.
    Any answers welcome, Barrie
  • smiley
    • Aug 2008
    • 615
    hi bro. just try to replace the tranrfer assembly maybe the electrode needle is not good or the primary corona is cut.
    there is no glory without sacrifice
      • 22999
      I haven't though of the NP1215 in ages. Here are a few possibilities in the order of likelihood:
      1) Wrong toner.
      2) Loose screws in the S-blade
      3) Poor contact at developer bias contacts on the rear frame.
      4) Bad HVT (FG1-7414-200).
      5) Worn out developer bearings.
      6) Magnets broken loose in the developing cylinder.
      Can parts even be gotten for this antique? =^..^=
      • mjarbar
        Hello all,
        First post after joining so hopes this is of help.
        The NP1215 was classed as obsolete in October 1990 with parts available till July 1996. So any major parts will not be available, however companies like Katun may still do things like rollers, toners, drum etc. As they are a world wide company I would check their web site for local contact and ordering details.
        Regards,
        Mjarbar
        • MisterQ
          Error Code.
          I have one of these that has been sitting in the corner for ages - just turned it on, and get an error code E 202. Does anyone know how to translate that into something meaningful? I want to have one last attempt at this before it hits the dumpster...
          Peter
            • 22999
            Take a look at connector J314 pin 1 on the DC controller. You may have a cold solder joint on that pin. It has somethong to do with the exposure lamp circuit. =^..^=
            • sun13zenith
              Peter
              _*_*_*_*_*_*_*_*_*_*_*_*_*_*_*_*
              Hello, The error code E202 means the fuse is blown. Remove the back panel and find the 5amp fuse, replace it with a new fuse. Restart and enjoy.
              Thank You
                • 16083
                Transfer End Blocks shorting out/ replace if u can find unit> if not R.I.P
                • davidj7
                  • 1107
                  i checked the local spare market for 1215 spares . some of the new guys dosen't know of such a model.
                  • SCREWTAPE
                    East Coast Imaging
                    • 3396
                    Here's a shot of that dinosaur.
                    • bineeshgeorge
                      • Jul 2009
                      • 107
                      Sounds like corrona arcing , you replace the upper and lower corrona units ( most probably is lower) good luck.
                        • 22999
                        Oh Man! That's bringing back some bad memories,
                        of slipping bed belts, overfilled waste toner reservoirs, fuser rollers caked with toner, image quality going light at the rear, warped bed fan ducts, ... I don't miss this one or any of it's decendents (NP2020, NP2120, NP6221). =^..^=
                          • 16083
                          time to put it to bed
                          • MrB
                            • Nov 2009
                            • 147
                            Chris.....lol
                            I decommed one of them the other mth
                            Was told it would be ending up in the skip
                            Think the other option woild of been a chalk and a blackboard lol
                              • 16083
                              case closed>>>
