Help!! iR C3080 Machine
  • q555
    • May 2015
    • 81
    PG Test 10 is working perfectly fine.
    But both Glass and Feeder Scan is not, there is a straight light output.
    Anyone have encountered this kind of problem in iR C3080 machines?
    Thanks in Advance!!!
  • q555
    • May 2015
    • 81
    Re: Help!! iR C3080 Machine
    We have also tried changing the Glass Board but no avail.
      • 8193
      Why you change a board for a copy quality issue!?
      I assume that is a copy of the PG10?
      I would first clean or replace the CCD.
      • q555
        • May 2015
        • 81
        Hi, i forgot to include the replacement of CCD. We first tried to replace the lamp, but no avail, same outcome, so we decided to replace the board, but still no avail.
          • 8193
          is that pg 10 a photocopy????????????
          • q555
            • May 2015
            • 81
            yes, i copied in the glass that PG10, and that is the outcome. There is a light printout (straight)
            PG10 test print is working perfectly fine.
              • 23010
              That indicates that you have some sort of dirty or obstructed optics. Either dirty CCD lens or mirrors, or some obstruction like a bent optical reflector. CCD's use RGB additive color, so either something is partially blocking the light path to the blue CCD array or the color of the dirt (mustard yellow) masks the blue light arriving at the blue CCD array.
              My guess is that you've got a bent reflector, a piece of insulating foam, or just something that shouldn't be there obstructing the light path to the blue CCD array. A good example is a customer of mine who copies thick books. They press down hard enough on the glass to warp the glass into the scanner path, bent the light source #1 reflector, and for them, throw the scanner cable. Three times they threw the rear scanner cable! It's on a Toshiba, but it illustrates the point.
              The funny part is that they continued to deny that they copy books, even when I handed them images from the trash that have that nice black outer margins, and you can see the edge of the pages. It's just stupid to continue lying when the evidence is right in front of you. =^..^=
                • 8193
                Poster has replaced the CCD & there are no reflectors or mirrors in the C3080 scanner!
                Have you tried scanning that PG 10 either to folder or email? is the image still the same?
                • tech28
                  • Jun 2013
                  • 434
                  Just looking at it, looks like the Cyan unit is bad, maybe), looking at the other colors, they look fine, black, magenta, yellow look good, just the cyan has a small line on top and then the lines more in middle, but just the cyan. Have seen weird copies when just scanning/copying, the lens had some cleaner that had hardened and causing the images come out with strange colored lines, eventually we had to change the lens, took care of problem. Good Luck.
                  • SAZ911
                    • Mar 2013
                    • 193
                    Hi ,
                    Check your Ribbon connector from the CIS to the Reader controller.....if you haven't already, had a similar issues, except the feint bands were much narrower..
                    Good luck.....
                    SAZ911..........
                    • zoraldinho
                      teacher-guide-expert-guru
                      • Mar 2008
                      • 5015
                      Zoom a pic!Stripes are on all colours!
                      Did you replace a ribbon cable?
                      • tech28
                        • Jun 2013
                        • 434
                        After taking a second look, yes its on all colors, also see the printouts under that one which is black, also on those, on top as well as in the middle. Optical problem.
                        • q555
                          • May 2015
                          • 81
                          hi good day,
                          update:
                          CCD replaced = same issue (no bend)
                          Board replaced = same issue
                          Photocopy & scan = same output
                          PG test print = working perfectly fine
                          Print = working perfectly fine
                          Have tried also using other ribbons = same issue
                          already puzzled with this machine, ahahahaha
                          • zoraldinho
                            • Mar 2008
                            • 5015
                            Any update?
                            • q555
                              • May 2015
                              • 81
                              No update yet with this kind of issue.
                              We already replaced the machine for the meantime, and this machine is under obrservation here in our office.
                              I will update as soon as possible.
