Anyone using cordless screw drivers for field work?
  • campy
    • May 2012
    • 315
    Thinking about getting one but have no idea what a good one is for copier repairs. How are they at getting into tight spaces and how do they fit in the Platt hard tool case?
  • copier tech
    • 8136
    Re: Anyone using cordless screw drivers for field work?
    Not worth it. Only takes a few seconds to undo a screw with a manual driver!
    Invest in a good quality ratchet driver I use a Snap-on.
    • campy
      • May 2012
      • 315
      I really don't like ratchet screwdrivers but which Snap on do you use? I use their old black handle magnetic screwdriver now and it's the best screwdriver I have ever used but they haven't been making them for probably 15-20 years.
      • allan
        RTFM!!
        • 5462
        With copier tech on this on. Not worth it.
        Will challenge anyone that claims to be faster with one.
        Whatever
        • JR2ALTA
          • Feb 2010
          • 2033
          I am not a "routine" kinda guy I could see myself with an uncharged driver half the time. Plus there are many screws that cannot be accessed without a long, traditional driver.
          I also don't like the ratchet drivers. God make screwdrivers pretty simple as it is and I can live with that.
            • 23003
            I can keep up with most electric screwdrivers with my Schroder (rebadged as Craftsman), and will never strip out a screw head or crossthread a screw:
            • NeoMatrix
              Senior Tech.
              • 3513
              Young lady tech gets a taxi home after a late night out...
              On arriving at her destination she finds that seatbelt is stuck.
              She looks at the cab driver smiles, and says "can you give me a screw driver"...
              An that is why the english language is very ambiguous...
              They're still married to this day.....
              • copier tech
                • 8136
                This is what I use 99% of the time.
                • tsbservice
                  Field tech
                  • 8002
                  At the moment I use one handheld screwdriver(not ratchet), it's always with me. In the shop I use mainly one gun type electric screwdriver(weights like a 400-500gr). Recently upon recommends from this forum(old thread) I purchased this:
                  Compact grip battery screwdriver with LED lighting | BataviaStore.com
                  It has really good feeling in hand, lightweight(150-160gr) and has long battery time, with just enough tork power for copier screws.
                  I used it big time with latest large numbers of copiers plus options to install and it do saves time and wrist power
                  That said I still use a lot my old handy screwdriver in many different situations ie in messy occasions, when more precise control is needed or in dark narrow places.
                  • clint@clintsimonsen.com
                    • 124
                    I've been using a Panasonic for about 12 years now. not for all jobs and not as much as I used to, machines don't have any screws anymore.
                    EY7410LA2S57 Tough Tool Drill Kits - Panasonic Australia
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Don't use I prefer snap on rachet and good 5.5mm magnetic nut driver
                      Regards Mark
                      • copier tech
                        • 8136
                          • 23003
                          In most cases it's optimistic to think that the customer can manage to swap units successfully, and at the right times.
                          A perfect example: on the Sharp Tiger series, Sharp made it just a little too easy to remove the developing unit, so we would frequently get calls that the toner cartridge that we sent them was the wrong type. Upon arrival I would see the developing unit missing, gone with yesterdays trash. And yes, you're going to have to pay for that. =^..^=
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4664
                            Cordless screwdriver, the most used tool in my bag. What a plus when removing the crazy amount of screws Jap's use now a days.
                            This is the one I use, small lightweight, balanced. Put a dewalt magnet tip holder and #2 phillips bit and good to go! it will drive a screw right though a 2x4 with no problem but torqe can be turned down for lighter applications like copier screws.
                            YouTube
                            • buzz
                              • Aug 2013
                              • 288
                              For the last 7 years of my 31 years in the bidness I switched to a Makita 18V cordless drill. Charge lasts forever. Its the best tool in the bag and I'll never go with out it. I use the long Milwaukee #2 Phillips bit, its the best bit I found so far, with its small diameter and perfect length it fits everywhere. I never need to pull out the super long manual Phillips.
                              Pros:
                              - Easy on the joints/wrist for machines with many screws for one panel
                              - Fast disassembly/reassembly without manually turning a screwdriver
                              - Torque setting default to increase screw longevity
                              - Adequate light on every turn of the screw
                              - Universal tool for drilling holes in older machine plastics and metals for modifications like securing zip ties
                              - Battery interchangeability with other tools in shop
                              Cons:
                              - High ticket
                              - Heavier than manual screwdriver
                              I
