Canon IR 5000 exit roller replacement
  • Philh
    • Dec 2011
    • 27
    [Misc] Canon IR 5000 exit roller replacement
    Can anyone advise me on the best way to replace the paper exit roller (shaft with 6 rubber rollers just left of heat fuser) Photo attached?canon delivery roillers.jpg
  • COPIERTEC ASSOCIATES
    • Aug 2011
    • 279
    Re: Canon IR 5000 exit roller replacement
    Originally posted by Philh
    Can anyone advise me on the best way to replace the paper exit roller (shaft with 6 rubber rollers just left of heat fuser) Photo attached?[ATTACH=CONFIG]54300[/ATTACH]
    1. Do you have the new exit roller itself?
    2. If you have the shaft roller,pull out unit 1,at the exit there is a metal plate attached with 2 screws one on either side unscrew to detach the plate and remove the circlip to remove the shaft.
    • Canuck
      Tech Specialist
      • 1713
      Is it jamming? One way gear ok? or is it tearing Legal? Common on these
      • Brian8506
        • 1664
        Remove external delivery assembly and metal plate below it. Then remove c clip from front of shaft. remove washer and bearing, slide the shaft to the rear, switch remaining parts to new shaft and reassemble. Very easy job.
