copying problem
  • waffu22
    • Jun 2009
    • 95
    copying problem
    i have a machine which is iR5000. the problem is,
    if i copy multiple copies there's a certain black copy come out (pure black copy).what should i do?
    please help me to resolve this problem.
    thanks
  • roho
    • Mar 2009
    • 844
    Does the black copy have the blanking on the lead edge? is the print solid black? any error codes? printing or copies only?
    need more info-i would start with the corona assemblies, replace the wires, clean optics and white plate, ccd adjust in service mode.
    If there is no lead edge blanking, i would look at the dev, process area for a foriegn object-i once had prints/copies in opposite relief thanks to a staple in the dev.
    • SCREWTAPE
      • Jun 2025
      Check the primary corona ass'y Check the grid, its probably arching.
        • 22997
        I've seen these symptoms with a paper clip stuck to the mag roller on the developing unit.
        • waffu22
          • Jun 2009
          • 95
          copying problem
          yes there is a blank on the lead edge.no error code happened. and then when i turn off the machine and on again it says reset unit one or reset unit 2.
          • roho
            • Mar 2009
            • 844
            Might be a long shot-check the drawer connectors, in particuliar the machine side. Some times a small piece of paper can block the connectors causing all kinds of malfunctions. As far as your CQ issue, i would start with cleaning optics, white plate, change corona wires, perform necc service mode functions for a start.
            • Kopyrtek
              Copier Psychologist
              • Jan 2007
              • 407
              All have left u great posts but what have you done so far to diagnose the problem?
